Let's talk Thunderjets
Old Aug 25, 2016 | 08:34 PM
J ballan's Avatar
J ballan
Hello everyone, I recently picked up a 429 thunder jet that I would like to go through and put into the 79 super cab I'm building. I know they came with higher compression ratios than regular 87 octane can handle. I think they were around 10.5 to 1 I believe. I was wondering if anybody is running one in there pickup and how it performs? All I know about it is it's been rebuilt (.060 over) and has hardened valve seats. Also it seems to run fine. Good oil pressure and compression. It came with a edelbrock rpm air gap manifold and a comp cam XM 262. I plan on using a 750 vac secondary carb and some Sanderson shorty swap headers. Any feedback or opinions on this would be appreciated. Thanks.
Old Aug 25, 2016 | 09:53 PM
flowney's Avatar
flowney
Cobra Jet? At .060 over, you are at the outer limit of bore size for this engine so think 2X before concluding that it needs to be "gone through." Any info on how far under the crank has been ground? Look for casting marks on the cylinder heads in hopes of finding D0VE. That's a winner,
Old Aug 25, 2016 | 10:03 PM
PA74F250's Avatar
PA74F250
Thunder jets were in T birds and I think some other bigger cars. It should have C8 or C9 heads on it. I think it would have had a better chance of have D0 heads if it was a later 429 Cj. Either way what he has is just as good for the most part, just a little more common.
Old Aug 26, 2016 | 02:43 AM
matthewq4b's Avatar
matthewq4b
It should run fine on good quality 87 octane. The 429/460 with any of the earlier heads were pretty resistant to detonation. And as stated 0.060" over bore is the limit for these blocks. If the exhaust ports have not been ported the gains with headers will be minimal at best, the exhaust ports are the choke point on these engines. The 750 vac secondary holley is an acceptable carb. If you really want to wake it up use the 700CFM double pumper instead, it will give you tire shredding launches and can still return decent fuel mileage if you can keep your foot out of it. (always a challenge with a double pumper)
Old Aug 26, 2016 | 07:27 AM
J ballan's Avatar
J ballan
No it's not a CJ just the more common Thunderjet. When I say gone through I don't mean any machine work. It still has the cross hatch on the cylinder walls. I'm just going to swap the cam, new gaskets, truck oil pan and such. Nothing major. and yes it has the D0VE-C heads.
Old Aug 26, 2016 | 07:31 AM
J ballan's Avatar
J ballan
I'll get the block casting numbers tonight and maybe Number Dummy can tell me what I have. Thanks everybody.
Old Aug 26, 2016 | 07:45 AM
J ballan's Avatar
J ballan
Block D1VE-6015-A2B
Heads D0VE-C
Old Aug 26, 2016 | 09:14 AM
DB429SCJ's Avatar
DB429SCJ
This is how I built mine:1978 F-100 SWB. 1970 429 TJ(N code). Block; DOVE-A(2-bolt CJ ) .030 .Crank .010-.010.Clevite full-groove bearings Melling HV pump. CJ rods, TRW forged pistons, speed-pro rings. Heads: DOVE-A, std.valve job, 428 CJ springs,Isky retainers and locks. Cam: General Kinetics hyd. flat-tappet 276/286 .503 lift. Edelbrock true-roller timing set. Fel-Pro 1018 head gaskets. Weiand steath intake, 780 cfm Holley vac. secondary. Stock DSII ign. Hedman headers,2.5 in. exh. C-6 trans. It runs good on 91 octane ethanol-free premium.
Old Aug 28, 2016 | 09:29 AM
J ballan's Avatar
J ballan
I don't plan on porting the heads but if it would really help maybe it's something to look into. I was going to buy some headers mainly because it came with car manifolds and rather than find truck manifolds I would just buy headers. Thanks.
Old Aug 28, 2016 | 09:45 AM
flowney's Avatar
flowney
Headers will always help but not as much as with some exhaust port improvements.
There are some terrific aftermarket heads that solve this problem nicely. Of course, this gets you perilously close to the slippery slope that leads to a complete top end performance package. That will get expensive.
Old Aug 28, 2016 | 02:47 PM
matthewq4b's Avatar
matthewq4b
Yes it would help a lot, the 385 series exhaust ports have all kinds of bumps and turns, just try to get your finger through it. You have the best stock heads for street use, the CJ heads are only an improvement if you will be spinning high RPM's or going to a stroker. Some minor contouring will help greatly and will help breathing more than anything else you can do.
Seriously consider getting some exhaust port work done on the heads. The intakes are fine and really need nothing done to them other than port matching your intake.
Old Aug 28, 2016 | 06:08 PM
J ballan's Avatar
J ballan
Since aftermarket heads are way out of my budget I will try and port them myself. Sounds like a fun challenge. Any idea what this combo will run for HP? I'm looking for more torque than HP. It's going into a hunting, trail driven, wood hauling F250.
Old Aug 28, 2016 | 06:24 PM
flowney's Avatar
flowney
Here is a benchmark that may prove useful. Scotty at RHP is "the man" and these are the prices his shop commands: Rein"Car"nation High Performance / porting services
He used to sell a PDF document for the DIY porter. Look for that if you'll be attacking this yourself. The danger, of course, is grinding through to a water port. Best have a good map drawn by someone in the know.
Old Aug 28, 2016 | 07:22 PM
orangeford's Avatar
orangeford
I second Scotty at RHP, had a recurve distributor done by him and used his porting instructions for porting the exhaust on my d3 heads. Have no idea how much difference the porting made but it had to make some difference. I never really ran the engine before mods in my truck to find out.
Old Aug 30, 2016 | 01:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Block casting number: D1VE-6015-A2B
Internal balance: 1971/73 429 / 1973/78 460 / Some 1979 460.
71Ranger97
Oct 2, 2014 04:57 PM
barca_texas
Aug 14, 2005 03:12 PM
drdemo35
Feb 17, 2004 11:54 AM
mustange70
Aug 21, 2002 08:34 AM
redranger1
Jan 28, 2002 09:42 AM
