Icp/IPR
Old Aug 25, 2016 | 09:24 AM
Rambo024's Avatar
Rambo024
Just talked to Jody he seems to think its the HPOP gonna pull it and send it to him.
Old Aug 25, 2016 | 11:15 AM
jhl3's Avatar
jhl3
Here is some additional food for thought while you think about the excellent advice given to you above...
Did Jody advise you to conduct the above tests in order to determine whether the HPOP is dying or not? If not, then why not?
Have you conducted any of the tests that were recommended? If not, Jody's opinion is exactly that, "an opinion", which is no better or worse than the free ones you have received from Pikachu and Tugly et al.
The difference is, the guys here on FTE are trying to save you money by not enticing you to send in a part that may not be broken. If you simply want a T500 which Jody sells then that changes everything. Many times a T500 is nice but is not necessary. However, what are you going to do if you get a T500 and it does not solve the problem? You are out about $500 and 7-10 days of down time with your truck.
Most of us do our testing first....
If the top most o-rings on the injector are blown and the bottoms ones aren't then there will not be oil in the fuel and therefore the fuel filter will be clean. The "Cody" test will determine this. The bottom ones could still be weak but the top ones bleed off the pressure before it manifests in the fuel bowl.
Old Aug 25, 2016 | 12:41 PM
Rambo024's Avatar
Rambo024
I agree with everything you said. At this point I'm gonna test some stuff tonight and if I can't get it. I will be sending it to a shop that works on lots of 7.3 you tell any mechanic that it's a van and their tone changes quick 😳
Old Aug 25, 2016 | 03:01 PM
Pikachu's Avatar
Pikachu
You can do that, but pulling it without actually diagnosing the problem may come back to bite you. It often does.
Old Aug 25, 2016 | 03:20 PM
Rambo024's Avatar
Rambo024
Agree 100% gotta do some maintaince on my other 7.3 cause that's gonna be my work truck until my van is back.
Will dig into the van here soon.
Will post my questions/results.
Old Aug 27, 2016 | 03:35 PM
Rambo024's Avatar
Rambo024
Update- decided to not test any farther and buy hpop from orileys needed van on road. It was the hpop! Van runs awesome.
Was to the point of sending it to a diesel shop. 2 diesel shops wouldn't even consider working on a 7.3 van and one was 3 weeks out.
They all said if it was a truck they'd do it no problem.
Did it with out the hop line removal tool. Big pain. After getting fuel bowl out it was straight forward. Having the proper swivel ratchet help a lot.
Thanks for all the help. I know should of tested and very surprised it didn't bite me. But it's running.
Old Aug 27, 2016 | 03:44 PM
AllaboutMPG's Avatar
AllaboutMPG
We all deserve a little good luck now and then. Glad it worked for you. Thanks for following up and letting us know the fix
Old Aug 27, 2016 | 04:08 PM
Rambo024's Avatar
Rambo024
Thanks.
Was so frustrated that I went to the Mercedes dealership yesterday and test drove a 2016 sprinter. Was about to buy it but figured I'd give my van one more shot. This van has been so good to me just can't give up on it.
Old Aug 28, 2016 | 07:59 AM
Tugly's Avatar
Tugly
Those Sprinters with the room to stand up are very tempting.
Good job chasing this down and reporting back!
ilateapex
Modular V10 (6.8l)
May 8, 2012 09:24 AM
overlandexpress
Oct 20, 2011 02:06 PM
slk133
Jul 11, 2011 08:54 PM
Blinko
Sep 23, 2001 03:30 PM
