1987 E250 Code reader test port location ?
Old Oct 19, 2011 | 02:52 PM
overlandexpress's Avatar
overlandexpress
I cannot locate where you plug in the code reader on my 1987 E250 van, Can anyone point out the location?
The van runs good but it hunts at idle and stalls when cold.
Any help would be appreciated
Old Oct 19, 2011 | 06:29 PM
carrfamilynj's Avatar
carrfamilynj
There is no OBDII port on that van. There should be a "EEC TEST" harness on the fender well under the hood, you have to jumper two of the lugs, turn on the key and read the sequence of CEL flashes(or use a test light), then look it up to decode. Watch the video below to learn more. They show a "test key" but you can just use a piece of wire to jumper the lugs.
<iframe src="http://www.youtube.com/embed/ivxDYSmGjHc" allowfullscreen="" frameborder="0" height="315" width="420"></iframe>
Old Oct 20, 2011 | 02:06 PM
overlandexpress
Thanks for the info, after watching the video I ordered an Equus #3145 Ford digital code reader from Amazon.com for $21.99 (Good Price) However if you want the 6 ft extension cord so you can sit in the van and read the codes from inside it's an additional $24.99, Dang cord cost more than the code reader!
Tim Foster
May 14, 2018 08:25 PM
Rambo024
23
Aug 28, 2016 07:59 AM
scatgo
May 3, 2008 09:49 AM
malveaux0089
May 26, 2007 09:50 PM
epos159
Nov 16, 2004 08:31 AM
