Auto choke
Old Sep 9, 2016 | 02:34 PM
FordFETruck's Avatar
FordFETruck
Originally Posted by LARIAT 85
Really? My automatic choke works great.
What "new carb" did you purchase? And was the choke fully electric, thermostatic, or...?
New summit carb. However the choke system is identical to any other full electric Holley. It was either too much tension, or not enough. It would come right back on in the winter after restarting and the high idle would be quite high when it did not need it. The high idle cams were too radical per step. It would either be fully on or it would kick off to the final one right off the bat. I got sick of that crap and went manual and love it.
Old Sep 9, 2016 | 03:16 PM
LARIAT 85's Avatar
LARIAT 85
I see.
What you are describing are the inherent problems with a fully electric choke. I had a Holley Avenger for a while and had similar results, no matter how I adjusted it. The stock Ford Autolite or Motorcraft carburetors used a thermostatic "hot air" automatic choke system with electric assist that works MUCH better.
Old Sep 9, 2016 | 03:34 PM
FordFETruck
I see.
As much as I disliked the Edelbrock carb my truck came with I will say that the electric choke on it worked fantastic after I got it set up just right. It would stay open for several hours due to the windings of the bimetallic spring being like 3X more than the Holley cap had. At least that's the only reason I could see why, it stayed hot to the touch for a long time. It also had much finer high idle cam steps and it would stay on longer when the engine was cold.
Old Sep 10, 2016 | 05:12 PM
Franklin2's Avatar
Franklin2
The better electric chokes use a sensor that bolts to the intake to tell the heating element in the choke how warm or cool the engine actually is. Like the kit below,, I believe the little black box with the large mounting tab is the temp sensor.
Old Sep 10, 2016 | 06:30 PM
FordFETruck
Even better than that is a divorced choke that sits in the intake with electric assist. Our van has that, and it works great. Needs a new thermostat though, the electric assist quit working, but the choke will still open itself after a little while due to the bimetallic spring sitting in a cavity in the intake. ALMOST as good as hot air, but for me I like setting it myself every time. No muss, no fuss.
73FordF100
Oct 25, 2010 03:17 PM
79FordBlake
Dec 13, 2009 12:30 AM
Nathan Plemons
Jun 30, 2009 06:44 AM
towmater
Jul 27, 2007 12:08 PM
stumpknockerr
Apr 25, 2005 01:10 PM
