Sponsored by: Kumho
Nicopp lines
Old Aug 21, 2016 | 02:58 PM
POPAJON's Avatar
POPAJON
Nicopp lines
I got to replace ALL the brakes lines on the "mistress" I came across this Nicopp brake line while surfing the web. It sounds like good stuff. Has anyone used it? Do you have to use special end fittings with this line? I am replacing ALL the brake stuff anyways.. Master cyl, booster, calipers proportioning valve etc. So I may as well do this to
Old Aug 21, 2016 | 04:12 PM
Tedster9's Avatar
Tedster9
It's great stuff, and easy to flare and work with.
Old Aug 21, 2016 | 04:16 PM
POPAJON's Avatar
POPAJON
Is there special end fittings or can you use the regular brass stuff?
Old Aug 22, 2016 | 09:13 AM
projectSHO89's Avatar
projectSHO89
I just used the simple double-flairing tool set I bought from Oreilly's for about $25. Worked fine with the nicopp tubing.
The brass fittings are the same as for steel lines.
Old Aug 28, 2016 | 07:41 AM
granny_rocket's Avatar
granny_rocket
The only difference between steel and ni-copp is that one rusts the other does not.
I replaced a few sections of brake lines on my front end with ni-copp. It definately bends into shape nicer and although others claim it's easy to flare I did have trouble flaring it BUT that being said, that could have been user error OR the junky parts store flaring kit I have. I couldn't get my flares right and had my local mechanic flare the ends for me. He has a hydraulic flaring tool. I've flaired many a steel brake line in my day.
If you're concerned about making the flares (which you really shouldn't) you can always buy pre-formed brake lines and bend them to shape. done and done.
Hope this helps and good luck,
Old Sep 2, 2016 | 09:25 PM
jetjockey99's Avatar
jetjockey99
The only thing better than ni-copp is stainless steel and that is much harder to work with. Harder to flare, harder to bend and a lot more expensive. Ni-copp works easily and uses standard fittings.
Old Sep 3, 2016 | 07:11 AM
FuzzFace2's Avatar
FuzzFace2
Also add to the SS line - hard to seal.
I have heard of people having leaks at fittings. Sometimes they can tighten it up more or loosen then tighten to get it to seal.
Others have had to replace the line/fitting with a re-flare to get it to seal.
And no I have not used SS lines because of the sealing issues on a car I am restoring.
Dave ----
jedijeb
Nov 24, 2022 11:46 AM
jerryst
Mar 25, 2012 04:52 PM
dlogan3762
13
May 16, 2010 02:56 AM
BarryMc
23
Jan 13, 2009 09:08 PM
arjr111
1997 - 2003 F150
Jun 23, 2008 02:18 PM
