rebuild/rebore engine
Old Aug 20, 2016 | 01:25 AM
JosePrado's Avatar
JosePrado
Hello
What is generally the going price to rebuild and rebore a ford engine?
Mine is a 241 straight 6 (1969 f100)
I don't know the tranny specs for my pick up. What might it be and what might the price be?
Thanks
Old Aug 20, 2016 | 09:30 AM
HIO Silver's Avatar
HIO Silver
Depends on a couple of basic factors... who is doing the disassembly or reassembly? Required machine work is determined upon inspection and measurement.. could just require a ball/hone... could require boring. Dunno.
For DIYer, Budget at least $1000 for machine work and up to $1000 for parts... oil pump, water pump, bearings, seals, a cam n lifters, rings, maybe pistons. Depends.
Old Aug 20, 2016 | 02:18 PM
Ford_Six's Avatar
Ford_Six
I had my last one bored .080" over for $150, but that was a buddy deal. On top of that I had pistons, rings, cam, lifters, bearings, seals, head gasket set, and a lot of my time. I had Delta make me a mid range torque cam (slightly higher lift and longer duration than stock), and was quite happy with it.
In your case, I would get the internals of a 300, or just rebuild a 300 to drop in. You will need a block from 86 or earlier, in 87 they made some changes including removing the z-bar mount and the mid sump dipstick hole. Your engine can be made into a 300 with crank and rods from any year 300, and pistons for a 65-73 300. As a bonus with that 240 head on it it'll have higher compression and give better performance.
Lilbrowntruck
Dec 10, 2016 10:54 AM
swmr1
Nov 12, 2013 11:55 PM
FordCardinal
Jan 24, 2005 07:55 PM
0270
Sep 7, 2004 08:45 PM
4BYFORDF150
Jun 15, 2004 03:20 PM
