Sponsored by: Real Truck
Starting issue
Old Aug 19, 2016 | 08:00 PM
theteichs's Avatar
theteichs
Starting issue
Hello everybody! My first time on this site, hope I am doing this correctly.
I have a '99 F-250 super duty with a 5.4 L engine and I am having trouble starting it. Initially it wouldn't turn over at all, so I had the battery checked, it was fine, and after charging it the engine would turn over very, very slowly once or twice then stop. I then replaced the starter and now it turns over very erratically but wont start. Any ideas?
Old Aug 20, 2016 | 06:08 AM
Chuck's First Ford's Avatar
Chuck's First Ford
was the battery TESTED using the 100 amp "LOAD" test.. all others are a joke.
bad connection of a battery cable. both positive and negative cables ... both ends.
bad battery cable.. is any part of a cable swelling? that is BAD.
and a New/rebuilt starter could be bad right out of the box.
engine must spin at a proper speed before it will start.. so...
battery, cables, starter.
Old Aug 20, 2016 | 12:49 PM
theteichs's Avatar
theteichs
Thank you responding to my question!
I had it tested at Napa, and this Napa is pretty good, as opposed to some I've been to, surprisingly. I didn't notice any swelling, and cables looked good, a little dirty.. Could it just be bad connections, as in using a wire brush to clean off contact points for the cables?
Old Aug 20, 2016 | 12:58 PM
Chuck's First Ford
do the easy, simple stuff first... clean/wire brush.. when done test and work from that.
but Ask Napa the type of test used.
Old Aug 20, 2016 | 02:27 PM
Tedster9's Avatar
Tedster9
A voltage drop test is easy to perform. While the circuit is under load during cranking.
Check both sides of the starting circuit one at a time. One probe of the voltmeter to the Negative battery post, the other to a clean unpainted part of the starter. Since electricity always follows the easiest path any voltage drop will show as a positive voltage. The limit is about 0.2 tenths of a volt. Same test with the positive side, lug on the starter to Positive battery post. The limit is a little higher maybe 0.3 tenths or so. Just from seeing the problems caused by bad cables over the years here it looks like once cables hit the 20 year mark or so they are done, definitely anything over 30.
Bum starters will draw WAY more current than a serviceable unit. This really smacks the battery hard. This can make the engine slow to start because the ignition is starved right when it needs it most, the starter is hogging all the juice.
drew1
30
Oct 3, 2014 06:19 AM
James Hiller
19
Mar 26, 2014 07:24 AM
Dustin_86
Jan 7, 2005 11:14 PM
iamme9182
Sep 26, 2003 04:33 PM
1979_F100_302
May 18, 2003 03:04 AM
