buzzed
Old Aug 19, 2016 | 02:09 PM
trentmac's Avatar
trentmac
buzzed
I have a 2007 f350 6.0l 4wd crew cab single rear wheel and the Brake light on the dash as well as the 4 wheel hi and low light come on at random times and will stay on for sometimes an hour at a time along with an awful buzzer sound.
Old Aug 19, 2016 | 02:25 PM
Blakshukvw's Avatar
Blakshukvw
Start be checking your brake fluid.
Old Aug 19, 2016 | 02:52 PM
trentmac's Avatar
trentmac
already did that
Old Aug 19, 2016 | 06:03 PM
trentmac's Avatar
trentmac
any other ideas? Would low brake fluid cause the 4 wd and 4low light to come on as well. I have the truck at the local dealer they cant fix because some reason wont do it for them. At time it Brake 4 wheel and 4 lo come and the buzzer will go for hours. The truck still runs fine except odometer goes out and cruse control wont work when this is happening. Please any help out there
Old Aug 19, 2016 | 08:32 PM
BLADE35's Avatar
BLADE35
Your kidding Ford Dealer?? Maybe its early Friday for those guys LOL
maybe time for new dealer
you would need to know what these circuts have in common maybe they share a harness IDK or Cluster issue
Sounds like Limp mode it goes into
What recent work has been done Last 5K say
Old Aug 20, 2016 | 01:09 PM
Yahiko's Avatar
Yahiko
You may want to have a look at the two connectors that plug into the
instrument cluster. The tiny wares can get damaged and cause problems.
When it misbehaving can you get the cluster to do a self test and sweep all
the needles?
If you happen to have the message center then you need to use this set
of instructions found here. >>>
https://www.fordtaurus.net/forums/viewtopic.php?t=9753
Instrument Cluster Self-Diagnostic Mode
To enter the instrument cluster self-diagnostic mode with the ignition key in the OFF position, press and hold the
odometer/trip reset button (except message center cluster) or simultaneously press and hold the message center
RESET and SETUP buttons (message center cluster). Turn the key to the RUN position and hold until the display
indicates TEST, usually within 3 to 5 seconds. Press the RESET button once to advance through each stage of the self-test.
To exit the instrument cluster self-test mode, turn the ignition to the OFF position. If no DTCs related to the concern are retrieved
Instrument Cluster Self-Diagnostic Mode Base cluster display Message center cluster display Description
tESt ENGINEERING TEST MODE Initial entry display into the self-test mode.
GAGE GAUGE TEST Carries out the gauge sweep of all gauges, then displays the present gauge values. Also carries
out the checksum test on ROM and EE.
All VF pixels illuminated All VF pixels illuminated Carries out the prove-out of all dot matrix pixels in all characters.
bulb TELLTALE TEST Illuminates all the micro-controlled lamps and LEDs.
PnXXXX Pn XX PART NUMBER XXXX - XX Return to normal operation of all micro-controlled lamps/LEDs and displays
the alpha-numeric prefix and suffix of the instrument cluster.
r XXXX FAIL ROM LEVEL $XXXX Displays the hexadecimal ROM level and type.
nr XXXX ROM LEVEL $XXXX Displays the hexadecimal ROM level and type as stored in the NVM.
EE XX NVM LEVEL $XX Displays the hexadecimal EE level.
dtXXXX MANUFACTURE DATE $XXX Displays hexadecimal coding of the final manufacturing test date.
CF1 XX - CF3XX B&A CONFIG BYTE 1$XX - 2$XX Displays hexadecimal of bytes 1-3 (non-message center cluster), displays
hexadecimal of bytes 1-2 (message center cluster) of module configuration settings.
dtc XXXX CONTINUOS DTC $XXXX Displays a 16-bit hexadecimal format. DTCs displayed are those detected in continuous
operation not during self-test.
E XXX.X VEHICLE SPD XX.X MPH Displays the imperial speed value being inputs in tenths of MPH to the instrument cluster,
the speedometer indicates the present speed.
XXX.X VEHICLE SPD XX.X KMH Displays the metric speed value being inputs in tenths of KMH to the instrument cluster, the
t XXXX TACHOMETER XXXX RPM Displays the tachometer value being input in RPM to the instrument cluster, tachometer
indicates the present rpm.
F1 XXX FDM FUEL LEVEL XXX RADS Displays the present FDM fuel level A/D input in decimal.
F1PXXX FDM FUEL %, STATUS XXX Displays the present FDM fuel level percent status in decimal.
F2 XXX JPM FUEL LVL XXX RADS Displays the present JPM fuel level percent ratio status in decimal.
F2PXXX JPM FUEL %, STATUS XXX Displays the present JPM fuel level A/D input in decimal.
FP XXX FUEL LEVEL %, STATUS XXX Displays the present weighted fuel level percent status in decimal (used by the gauge).
FiXXXX FUEL INT STATUS XX XX Displays the fuel int reference type used at the key on int in hexadecimal, followed by the
FLPS value of the int reference in hexadecimal.
XXX C COOLANT TEMP XXX C Displays the last temperature gauge input value from the HS CAN in degrees C, temperature
gauge indicates the present temperature.
odoXXX ODOMETER XXX COUNTS Displays the odometer input received via the HS CAN, in decimal.
toXXX.X TRIP ODO XXXX.X Displays the trip odometer value stored in RAM in miles.
bAtXX.X BATTERY XX.X VOLTS Displays the present VBAT A/D reading in volts.
rS -X RUN/START X RUN/START sense circuit check.
rA -X RUN/ACC X RUN/ACC sense circuit check.
iin -X KEY IN SW X Displays the input status of key-in-switch.
dC XXX DIMMING CMD XXX Display of the SJB dimming command in decimal.
dS XX DIMMING STEP XX Display of the instrument cluster dimming step in decimal.
MC SWITCH XXX A/D CNTS Displays the present message center switch input A/D counts in decimal.
tCsXXX TC ON/OFF SW XXX A/D CNTS Displays the present input status of the traction control on/off switch ratio in decimal.
ACr XX AC REQUEST X Displays the input status of AC request switch.
PARK INT SW XXX Displays the present park interlock switch input A/D counts in decimal.
COMPASS INPUT $XX Displays the data being received over the compass network in hexadecimal.
dor XX DOOR STATUS $XX Displays the door ajar status received from the SJB in hexadecimal.
H t XX HL & TURN STATUS $XX Displays the headlamp and turn signal status received from the SJB in hexadecimal.
Ad XX AWD DATA $XX Displays the last AWD indicator command received from the 4x4 control module, this command shares
the stability control indicator.
PCXXXX PCM DATA $XXXX Displays the 16-bit hexadecimal value of indicator commands and fuel flow received by the PCM.
trXXXX TRANSMISSION DATA $XXXX Displays the transmission wrench indicator, the MIL indicator as commanded by the transmission
state, and the PRNDL information received from the traction control module in hexadecimal.
AbXXXX ABS TT DATA $XXXX Displays the status of the indicator commands received from the ABS/TC/IVD module in hexadecimal.
rC XX RESTRAINTS CMDS $XX Displays the status of the air bag, the safety belt indicators, and the safety belt chime commands
from the RCM in hexadecimal from the input message.
tt XX SJB TELLTALE STATUS $XX Displays the telltale status received from the SJB in hexadecimal.
tS XX SJB TURN SIG STATUS $XX Displays the turn signal status received from the SJB in hexadecimal.
Ch X LAST CHIME SOUNDED X Displays either the chime last sounded by the instrument cluster, or the chime that is presently
sounding. This excludes the trip reset button press chime used to enter the ETM or to scroll through the ETM.
PAd00-PAd09 XXXX PORT AD00-PORT AD09 $XXXX Displays the 10-bit hexadecimal values of the ports AD00-AD09 A/D read.
PA XX PORT A $XX Displays the 8-bit hexadecimal value of the port A readings.
Pb XX PORT B $XX Displays the 8-bit hexadecimal value of the port B readings.
PJ XX PORT J$XX Displays the 8-bit hexadecimal value of the port J readings.
PK XX PORT K $XX Displays the 8-bit hexadecimal value of the port K readings.
PL XX PORT L $XX Displays the 8-bit hexadecimal value of the port L readings.
Pnn XX PORT M $XX Displays the 8-bit hexadecimal value of the port M readings.
PP XX PORT P $XX Displays the 8-bit hexadecimal value of the port P readings.
PS XX PORT S $XX Displays the 8-bit hexadecimal value of the port S readings.
Puu XX PORT W $XX Displays the 8-bit hexadecimal value of the port W readings.
GAGE GAUGE TEST Repeats the test display cycle.
This should give you some things to check out.
Sean <BR>
6.0L Tech Folder
bigcountry1009
Dec 4, 2021 02:19 PM
thatsrealnice
Sep 27, 2011 06:35 AM
snowman79
Escape & Escape Hybrid
Feb 18, 2009 07:58 PM
Pete in Maine
Aug 21, 2008 12:22 AM
MMW
Feb 17, 2005 03:46 PM
