Brake light
Old Sep 26, 2011 | 11:17 PM
thatsrealnice's Avatar
thatsrealnice
Brake light
As long as I've owned my truck, the brake light has been on. Well the last time I drove it, the light has been off, and coming on periodically, then going off again. What do you think the problem could be? Prop valve? Brake pressure warning switch? Or both? Any ideas would be appreciated.
Old Sep 27, 2011 | 06:20 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Normally that light is suppose to come on when you have a serious brake problem. Like a sudden loss of fluid from the system some where. Blown rear wheel cylinder, rusted frame line, ruptured rubber line going to rear axle?
And to prevent that, the proportional valve piston moves to stop the rapid flow of fluid and trip the light.
Since its been on most of the time, have you brakes been normal? Sounds like the truck had a brake fluid loss issue sometime and was fixed and the PO could not get the pro valve piston to recenter.
Sounds like it has fixed itself, I would suggest a full brake system bleed.
Old Sep 27, 2011 | 06:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The plastic low brake fluid warning light switch threads into proportioning valve. It's notorious for developing cracks in its threads, causing brake fluid to seep out.
When this occurres, the low brake fluid warning light on the dash comes on...and stays on.
C8AZ-2B264-A .. Low Brake Fluid Warning Light Switch / Available from Ford and a gazillion autoparts stores.
Applications: 1968/79 F100/350, Bronco and Econoline, 1968/69 FoMoCo Passenger Cars (1967 is one year only).
bigcountry1009
Dec 4, 2021 02:19 PM
Savage19NRA
Mar 8, 2018 01:07 PM
snowman79
Escape & Escape Hybrid
Feb 18, 2009 07:58 PM
alconk
Jan 13, 2009 10:52 PM
dalman
2004 - 2008 F150
Oct 28, 2007 07:41 AM
