Mileage or Yardage ?
Old Aug 19, 2016 | 11:34 AM
Pew Professional's Avatar
Pew Professional
(Sorry if this has been beat to death...)
Filled up the X last night , 30 gallons and I still had 1/4 tank left.
I ran the numbers and it looks like im getting 10.5 MPG around town.
I have the 6.0 , there is a 6 inch lift on the truck.
The SCT tuner is set to "street" tune and I really dont get on the throttle too much in town.
I hear some folks getting closer to 15 around town , some even close to 20 mpg on the highway.
Any suggestions or ideas on improving the mileage?
Will setting the tuner for a more aggressive tune help or hinder ?
Thanks guys.
Old Aug 19, 2016 | 12:37 PM
Blakshukvw's Avatar
Blakshukvw
Tire size, gears?
Old Aug 19, 2016 | 12:47 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Back when I had a 6ohno it got horrible mileage also which irked me to no end because I had switched from a 7.3
11mpg doesn't surprise me.
14 -15 might be doable on a road trip going the speed limit
16-17 is probably the lie o meter lulling owners sensibilities
18-20 you'll need more then a grain of salt
Old Aug 19, 2016 | 01:04 PM
Blakshukvw's Avatar
Blakshukvw
I have an 03 6.0 285/75's no lift, no tune, and 175k on original injectors and I consistently get 13.5 mixed driving. Do you use any additive?
Old Aug 19, 2016 | 03:15 PM
Pew Professional
I am not sure on the gears.
Its got 22x12.5 rims on 35 inch tires
The previous owner ran Rev X in the tank and oil every few months
Old Aug 19, 2016 | 07:32 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Thanks guys.
That is pretty bad. That is close to what I get towing around the 13500lb toy hauler.
Double check your math and try adding some diesel additive into a tank of fuel. I alternate between diesel kleen and 2 stroke marine oil every other fill up. It may not do a damn thing to help but I do have 324k miles and get 50% better fuel mileage than what you're seeing....just saying.
Its all how you drive it and what you have on it. Before the rack, mirrors and tires I was seeing 22mpg on cross country trips. Now I am around 18mpg when just highway and roughly 15-16 with mixed driving.
Old Aug 19, 2016 | 07:56 PM
pirate4x4_camo
Has your speedometer been set for the tire size ?
If not a 35" tire is 577 revs per mile compared to the stock tires 638 so roughly 10% off.
If your computer has not been reprogrammed to the correct revs per mile for the tire size then your 10.5mpg is really closer to 12 mpg
Old Aug 19, 2016 | 08:12 PM
Pew Professional
Thanks everyone. I just set the SCT programmer to Performance, just to see if there is any changes.
The manual states it for economy and racing. I dont see how those two things can exist at the same time...
Ant thing to watch out for with the more aggressive tune?
Old Aug 19, 2016 | 09:07 PM
Pew Professional
well , just took it out for a quick run - WOW!
this thing has some power now!
Performance tune on the SCT is night and day different from the street tune.
and the scan gauge is telling me im at 15.5 mpg! its playing with my emotions
Old Aug 19, 2016 | 10:41 PM
pirate4x4_camo
See my previous post....
Until you correct for tire size neither the vehicle computer or the SCT computer knows how many times the tire is revolving or your true speed or mileage.
Old Aug 20, 2016 | 05:25 AM
WE3ZS's Avatar
WE3ZS
Yeah, double check your speedo vs a GPS. Larger than stock tires will throw off the speedo/odo/MPG if not reprogrammed for them.
Old Aug 20, 2016 | 07:25 AM
Blakshukvw's Avatar
Blakshukvw
I run stanadyne in every tank. When I forget I see a small drop in mpg and idle suffers a bit. Won't hurt to run some as stated above. A ficm tune is said to add some mpg. Someone that had one should chime in.
I wish I could get 15 to 16mpg.
Old Aug 20, 2016 | 08:28 AM
cameeks's Avatar
cameeks
You are doing the math right? Your not going by the overhead gauge.
Old Aug 20, 2016 | 01:36 PM
hwybee22's Avatar
hwybee22
Your fuel mileage is sucked away by your 35s and 22in rims.
Old Aug 20, 2016 | 02:09 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
FICM tunes do indeed help most folks. Tuning options are listed at PHP Tunes. We can also set you up with a loaner tuner to eliminate downtime at Gryphon Loaner FICM Tuner.
