At 13,000 miles, I'd check the coolant level and make sure it was full. If I knew that nobody had added anything my coolant, I probably wouldn't worry about testing the coolant. Nitrites only happen if somebody put the wrong coolant in your cooling system. Freeze protection should still be excellent on a truck with that low of miles. From what I've seen testing a number of these systems. I'm just not seeing the Corrosion inhibitors failing for the first few test.
Air in your cooling system is a bad thing. So make sure your cooling system is topped off.
I called my dealer and they didn't impress me with their knowledge on the coolant testing. The guy actually told me that the would just put the additive in and not do the test.... Not Good
10-4 Daystrom - the previous owner has the coolant flushed at 60K - so since I only have about 12K on it I don't think it should need the additive just yet. But the guy in service wasn't aware that the additive can only added 2x.... That's why I went with DIY.
From reading on other forums most state to not test in the reservoir but to take a sample from the petcock on the bottom of the radiator. Any thoughts? I looked up a video on youtube and it has a Ford A mechanic performing the test at the reservoir.
It is virtually impossible to take a sample from the secondary cooling system resevour. I'm my 2016 there is a shield/splash guard that blocks ones ability to get a sample from the resevour. I tried with a long wand and it came back dry. The external visual has the fluid at the correct level. It appears that the only way to sample the secondary coolant system is by taking a sample from the peacock.
If the Ford advisor is performing the test just from the resevour, I bet they are only sampling the primary coolant system.
I called the dealer when I got the coolant check message at around 13K miles. They said they never bother doing the tests and I could bring it in and have them reset the message or do it myself. I wasn't too happy with that response, but I just reset it. I'll find a dealer to test it the next time the message pops up or buy the stuff to do it myself.
