General Diesel Discussion
Help needed. Transmission??
Old Aug 17, 2016 | 04:01 AM
Chrisgallo's Avatar
Chrisgallo
I just got a 1991 f250 diesel 2wd. It has the e40d transmission in it. It has only 91000 original miles on it.
Well when I went and got it, it drove good for about 80 miles then I was cruising at like 70 on the interstate and all of the sudden the Rpms went up and the speed went down. The gear didn't catch again until about 50mph.
Now SOMETIMES when we get in I get hard shifts and it acts like it doesn't want to shift or wants to go back and forth. But then sometimes it's really smooth shifting. It had started doing that so we changed the trans fluid and there was no big metal flakes in the pan or anything like that. Added the oil back and added Lucas anti slip stuff.
But it still does it only sometimes.
Off of those details can anyone tell if the trans is bad or if it may be the solenoid pack inside the trans that is going bad. Or am I way off?
I also went and talked to a transmission shop and they actually said it sounded more like the TPS than anything else.
Any help would be appreciated
Old Aug 17, 2016 | 07:11 AM
lee00's Avatar
lee00
It could be a lot of things...
You might get a better response from the pre power stroke idi forum...
I don't know these trucks that well...
Old Aug 17, 2016 | 10:46 PM
Ford_Six's Avatar
Ford_Six
TPS, harness, or speed sensors.
Old Aug 18, 2016 | 06:59 AM
lee00's Avatar
lee00
  • Originally Posted by Ford_Six
that's what I was thinking....causing TC to unlock maybe?
Old Aug 18, 2016 | 11:37 PM
Ford_Six's Avatar
Ford_Six
The computer (any computer) can only make it's decisions based on the input it gets. If the input doesn't make sense, then it won't know what to do and will generally go into a fail-safe mode.
In the case of the transmission controller in your truck, the shift strategy is controlled by a map. If the TPS is at X, the fluid temp is at Y, speed is Z, then it needs to be in a certain gear or shift a certain way. If any of that input is outside of the map, it has no idea what to do.
Chrisgallo
Aug 28, 2016 08:46 PM
Chrisgallo
General Automotive Discussion
Aug 18, 2016 04:36 PM
ilo9
Feb 4, 2010 07:35 AM
David85
30
Jul 8, 2008 08:05 PM
frankoholic78
Aug 12, 2003 08:52 AM
