E4OD question
Old Aug 16, 2016 | 01:56 AM
iron butterfly's Avatar
iron butterfly
E4OD question
My son has a 1995 f250 4x4 7.3l powerstroke. Earlier this year it lost the convertor clutch. Since it had 200k+ we rebuilt the trans with upgraded convertor and clutches, the pump had some issues so it was also replaced with a rebuilt pump with flow upgrades. When we reinstalled it we put a 6.0l cooler in. The trans works great but when the temp gets over 165*F (measured at the pan) the shift into OD becomes sluggish. As soon as the temperature goes down it returns to normal. Is this something that needs to be addressed? I owned the truck for several years and pulled a gooseneck with it a lot and don't recall it doing this but on the same token I ran in tow haul mode most of the time unless the trailer was empty.
Old Aug 16, 2016 | 08:34 AM
Lead Head's Avatar
Lead Head
What do you mean sluggish? As in the shift it self is slow, or it waits awhile before shifting into OD?
Old Aug 16, 2016 | 11:22 AM
iron butterfly
E4OD question
From the way he describes it the shift itself is slow
Old Aug 16, 2016 | 12:13 PM
Lead Head's Avatar
Lead Head
Sounds like either an EPC control problem (bad solenoid pack?) or the transmission has an internal leak somewhere than for the over-drive section.
david1993
Apr 20, 2011 07:54 PM
liberty2701
May 29, 2009 07:14 AM
stormyone
May 12, 2007 03:37 PM
Bob 86
1978 - 1996 Big Bronco
Jan 13, 2003 08:56 PM
captntim
Jan 12, 2003 11:35 PM
