1978 - 1996 Big Bronco
E4OD
Old Jan 12, 2003 | 03:03 PM
Bob 86's Avatar
Bob 86
E4OD
I bought a 96 Bronco that needed the trans rebuilt. Well after getting the trans rebuilt and had a trans-go shift kit installed along with a new solenoid pack. Still had no 1st or OD. After some wire tracing found the PCM to be bad. 2nd gear circuit stuck grounded. Problem fixed. Now when the outside temp is under 50 degrees the trans will not shift into OD untill the temp gage hits the first mark in the "normal" zone. Is it working correctly or is there another problem? I know on Benzes there is no OD till a certain temp. I ask some dealer tech, but no one knows.
Old Jan 12, 2003 | 06:47 PM
screwy's Avatar
screwy
E4OD
Mine shifts into OD when cold.
96 Bronco, Eddie Bauer, 351w
Old Jan 12, 2003 | 07:15 PM
90EBBronco's Avatar
90EBBronco
E4OD
I had my E4OD rebuilt last year and now I don't have automatic 2nd or overdrive. I have to shift into second manually and don't have any OD. I replaced the shift solenoid and it still doesn't work. Do you have any ideas as to where I can start to troubleshoot this problem? Much appreciated.
KJ
Old Jan 12, 2003 | 08:33 PM
BOJOFASO's Avatar
BOJOFASO
E4OD
i have a 91 5.8 e40d and mine doesnt shift into overdrive until temp is on the normal line. thats not so bad it warms up to that point in about 3 minutes.
Old Jan 12, 2003 | 11:00 PM
tothfngclw's Avatar
tothfngclw
E4OD
My 91 5.0 E4OD shifts into overdrive while cold. There were alot of updates on this trans that are suppose to be performed when they are rebuilt also if I remember correctly the lines to the trans cooler have to be flushed after a rebuild, some even recommend changing the cooler if the trans died altogether. If you do some research online you will find that some shops that sell the E4OD will not warranty them if these changes are not made.
Old Jan 13, 2003 | 08:07 PM
Bob 86's Avatar
Bob 86
E4OD
After searching through a Ford powertrain manual I found that there is a trans fluid temp sensor and if the fluid is a certain temp the computer will change shift timing and disable lock-up untill a certain temp is reached. The scan tool showed 2nd, 3rd and 4th, but no lock-up in any gear till trans temp reached 50 degrees. 90EB Bronco sounds like a solenoid pack problem or computer. You would have to find if the trans is getting the command for 2nd or OD. Then if A & B solenoids are turning on and off. I think it goes if A on only that is 1st A&B is second, B only is third, both off will go in to OD. I think that is how it goes, if I am wrong I will post tommorrow and make corrections.
Old Jan 13, 2003 | 08:56 PM
Miketnf150's Avatar
Miketnf150
E4OD
forensicpsyguy
Nov 24, 2019 02:59 PM
maytag906
13
Feb 10, 2014 05:30 PM
autotech2
25
Oct 16, 2011 12:37 PM
forensicpsyguy
Feb 14, 2010 03:38 PM
