1978 - 1996 Big Bronco
73-79 leaf springs
Old Aug 16, 2016 | 12:25 AM
black & blue 78/9's Avatar
black & blue 78/9
73-79 leaf springs
I have searched but I am not good at finding things. Easy question with hopefully an easy answer. I have a 79 Bronco and my rear springs are sagging badly.
Will 73-79 f250 2x or 4x leaf springs fit? Spring eye to spring eye and center pin. I think f150 springs will be to light for my Bronco. Maybe not. I tow a small trailer, MAX 3500-4000 pounds. It is 12', single axel. I have towed this much twice in 11 years.
Any help would be appreciated.
Thank you Chris
Old Aug 16, 2016 | 12:28 AM
Tedster9's Avatar
Tedster9
A large truck repair shop near you should be able to make whatever you need, and for a competitive price, and no shipping charges.
Old Aug 16, 2016 | 01:48 AM
black & blue 78/9
Thank you Tedster9 for the quick answer. I was thinking of using some springs from the junk yard because the local yard has many of the trucks there with the beds already off. I am heading there this weekend for something else. I know to get both sides and to use them as a pair.
Old Aug 16, 2016 | 06:50 AM
gatorfor88's Avatar
gatorfor88
F150 springs will be rated for heavier use than Bronco springs. And should be a direct bolt in. F250 springs even if they do "fit" will make the rear end so stiff you can barely drive it on the road. You dont want the tires to be the suspension.
http://www.thesuspensionking.com/catalog/
Old Aug 16, 2016 | 11:05 AM
Tedster9's Avatar
Tedster9
Used springs will of course fit but it's a fair amount of work to swap them out, the issue is they may not be any better than what's in there now.
Old Aug 16, 2016 | 01:33 PM
Kemicalburns's Avatar
Kemicalburns
look into some Deaver springs or perhaps some ProComp spring packs. ive been happy with mine even with a trailer on the back.
Lil_Bud_89
Feb 25, 2007 11:36 PM
78fordranger
Aug 6, 2006 10:34 AM
86302
Jul 24, 2005 09:37 PM
hitecdan
Aug 5, 2002 04:22 PM
roscoe
Mar 1, 2001 05:43 PM
