ok now is it possible to put rear leaf springs on the front of a 78 f 250 or will they not fit between the shackles. (length wise) or is it better to keep the stock 2 leaf, leaf springs?
i guess i should ask this first. well i just bought this truck and are them front leaves suppose to sag like there more horisontal and not really in a preloaded state if that makes sense.
you have a 4x I suppose, I believe most of those trucks came with reversed arch springs, I think it had to do with ride quality. If I am wrong, someone will give you the real scoop on the matter.
On another note, 30 year old springs will sag, in your case arch more, check around for a local spring shop, most will bring the springs back to life or offer you an add a leaf system to get it to the original height.
I have 78 250 4X4. I have to haul around about 800 lbs. of tools. It was looking a little low this spring so I took it to a local spring shop and they re-arched and added a leaf on a four corners for around $365. And it looks really good now. Put 33's under it. Erv
It has been my experience that a properly re-arched spring will last a long time. Springs will obviously crack due to corrosion or stress risers over time. A good spring tech knows what to look for when checking over springs and will replace those leaves that show signs of cracks developing.
All depends on use. If your truck is just a daily driver the re-arch will last for awhile. If you constantly are hauling heavy loads, the arch won't last.
A leaf in a truck spring generally can take between 2-4 ton of pressure to arch when new. I have re-ached some older springs that would bend between 1 and 2. Structurally they would be fine - minimal rust, no cracks, decent bushings - but the use they had seen over the years had softened them greatly.
For appearance only, a re-arch is fine, but for hauling purposes, I would recommend new springs, or an add-a-leaf at the very least.
Hmmm, when done at my local spring shop re-arched springs have been just fine when hauling heavy loads. It is possible they would have thrown out a leaf that took to little pressure to re-arch. The pressure required would depend on the thickness and deflection. The operator kept his eyes on the pressure gage and the springs very carefully. Bending a soft spring and using it would seem to be an operator error.
When you add a leaf, make sure your U-bolts are long enough to get the entire nut threaded on. When I was reassembling my chassis during my restore project, I noticed my U-bolts Nuts would bottom out before the Nut cleared the bottom of the U-bolt. The bolts werent' long enough. I didn't realized the PO had added a leaf. So, I had to get custom new ones long enough so at least 4 or 5 threads or so would stick through the nut. I didn't feel like losing my front axle driving down the road.
