1978 - 1996 Big Bronco
Bronco backwards shock mounts
Old Aug 14, 2016 | 02:47 PM
gov2mod's Avatar
gov2mod
I was getting ready to install a rear 8.8 differential in my 1993 Bronco when I noticed that the shock mounts on the new rear axle were facing to the rear instead of the front. This was a junkyard rear axle I've had sitting around for a couple of years and it was supposed to be out of a Bronco although a F150 should have been the same. It is an 8.8, has the anti-lock trigger gear inside, has the electrical plug on top, and is new enough to use the flat pinion flange for the drive shaft. It didn't come with the sway bar but I was going to unbolt that from the old and transfer it to the new.
I have the rear out of my 93 and was in the process of changing some parts from the old one to the new one when I noticed the difference. The new differential has the shock mounts facing the rear while the 93 has them facing the front. I looked at my 91 Bronco as well as the rear that came out of my 91 and all three rears, the 93, 91, and the one that came out of the 91 all have front facing shock mounts. What differential do I have?
Old Aug 14, 2016 | 04:29 PM
gov2mod's Avatar
gov2mod
I believe I've solved the mystery. It looks like this rear is from a newer truck, maybe late 90's. I just noticed the lugs have a courser thread than the 1/2-20 size on my other Bronco's and when I checked a 5.5" pattern drum from the 93 against it, it had the smaller (approx: 5&3/8") metric bolt pattern. I saw the Bronco it was supposed to come from but maybe they had this one out and thought it was the same. Either way it's way too late to take it back. I guess I can use the gear set from it to rebuild one of the other differentials.
Old Aug 15, 2016 | 10:41 AM
Kemicalburns's Avatar
Kemicalburns
is the WMS to WMS the same on both your current rear diff and this mystery diff? Perhaps it came out of a Van or a 97 F150 running the metric bolt pattern.
Old Aug 15, 2016 | 02:36 PM
gov2mod's Avatar
gov2mod
The brake backing plates are a couple inches farther apart as are the perches for the leaf springs. I think it probably came from a 97 or newer F150.
Old Aug 16, 2016 | 01:31 PM
Kemicalburns
yea i figured, the R&P probably isnt the same either. I think the 97 trucks was a larger 9.75 ring an pinion or something like that.
Old Aug 16, 2016 | 06:34 PM
gov2mod's Avatar
gov2mod
I looked at the ring gear to see if it was a 3:55 and it was, I didn't check the diameter.
Richard77
Bronco II
Mar 17, 2016 09:38 PM
racinrandall
Jan 21, 2013 09:08 AM
SuperDutyScaler
Aug 31, 2009 06:52 PM
anaconda
Offroad & 4x4
Feb 7, 2005 10:06 AM
02superstroker
Jan 13, 2004 12:00 PM
