Oil Type
Old Aug 19, 2003 | 09:42 PM
i_alone's Avatar
i_alone
Oil Type
I have an 83 F100 with a SROD manual trans, I was wondering what is the best oil to put in there, Gear oil, or ATF? I live up in the colder climates of canada and I will be drivig it in the winter.
any suggestions?
Old Aug 20, 2003 | 10:40 AM
jim henderson's Avatar
jim henderson
Oil Type
Always read the manual if you have one or hope someone on this website knows. Also sometimes there is a tag on the tranny that might specify fluid type.
A wild guess is that you need gear lube. I don't think ford manuals went with atf until the mid 80s and probably only for light duty. I am no expert so don't bet on my opinion.
In Canada I would probably go with a 75W90 or even better go with a synthetic.
The older 90W140 gear lubes are like peanut butter in freezing conditions and it can be hard to shift and may cause increased wear in cold climates.
Just my opinions,
Jim Henderson
Old Aug 20, 2003 | 11:27 PM
i_alone's Avatar
i_alone
Oil Type
The Ford manual says Standard Transmission Fluid? what ever that is, I will call Ford tomorrow and see what they recomend
Old Aug 21, 2003 | 12:23 AM
andym's Avatar
andym
Oil Type
I'll side with Jim on this one. Use synthetic 75W90 gear oil.
Old Aug 21, 2003 | 05:48 PM
i_alone's Avatar
i_alone
Oil Type
hmmm, ok, thanks I will look into that, I'm not too sure what they sell that for north of the border here
Old Aug 21, 2003 | 06:52 PM
rclarke's Avatar
rclarke
Oil Type
The Ford standard transmission oil is an 80 wgt oil (not gear oil) that is only available from Ford dealers. Most dealers won't even stock it. Before I retired we were using and 80/90 synthetic that worked fine.
Old Aug 21, 2003 | 09:16 PM
i_alone's Avatar
i_alone
Oil Type
yeah, that's what the guys at my Ford dealership said
matowns21
19
Dec 30, 2011 09:27 AM
powerman01
Jan 23, 2009 04:08 PM
Adam0331
40
Aug 31, 2008 09:09 AM
rmcmillion2006
Dec 12, 2007 11:42 PM
wresleu
Aerostar
Jan 23, 2006 12:52 AM
