Power window Kits?
Old Dec 17, 2016 | 11:40 AM
  #31
Moe Craig's Avatar
Moe Craig
Originally Posted by gerrymoe
Thanx John
I had the ones Smallello used and I did not like the crimp in the tubing when door was wide open. I like the design of the electric life product you used so I ordered them.
I actually looked into a hyme joint to see if I could make the ones I have work but it would have been totally to big.
On a side note if anyone on here needs a power window kit, bought from Mid-Fifties with install kit, never been used. I bought the Nu-Relics. It is yours for the cost of shipping.
Page 96 Mid-Fifties 2015 catalog-part #1740-ex
MERRY x-MAS to all
How much do you think shipping will be to Mesa, AZ 85202? I'm thinking about changing to power
Old Dec 17, 2016 | 12:01 PM
  #32
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
I used these on my panel, easy install and no problems, comes with everything you need. I have solid side windows so you should have no problems.
EZ Wiring E-Store - Power Window Kit
John,
These say Flat Glass only I thought you had MidFiftys kit that says it's curved. No problems with your installation?
Old Dec 17, 2016 | 12:58 PM
  #33
56panelford's Avatar
56panelford
Originally Posted by bjmayberry2
John,
The only curved glass I have is the windshield everything else is flat. I bought the power window drives from EZwire and the glass kit was from Midfifty. I had no problems installing the kits..
Old Dec 19, 2016 | 12:53 PM
  #34
smallello's Avatar
smallello
Are we there yet?
John,
I used EZ wire to wire my truck like you did.
When I connected the power windows they are on all the time. I assumed they would be on in the acc or ign position only.
Is the power window circuit always on for you too?
Old Dec 19, 2016 | 08:08 PM
  #35
56panelford
Mine only work with the ignition on..
Old Dec 20, 2016 | 11:37 PM
  #36
smallello's Avatar
smallello
Are we there yet?
I looked at the back of the fuse panel and the power window circuit is wired to the BATT not ACC. I assume it was supposed to be wired to the ACC. I am going to call Dolphin tomorrow and see what they say.
Old Dec 21, 2016 | 11:58 AM
  #37
smallello's Avatar
smallello
Are we there yet?
I called Dolphin and they tell me the power window circuit is an "always on" circuit. He said I could wire it to any ACC circuit if I want it to be only on with the key.
Since I have lighted switches I will do that but I will use the power window circuit with a relay to control it.
Old Jan 11, 2017 | 12:49 PM
  #38
55Wizard's Avatar
55Wizard
gerrymoe, is this window kit still available?
I'm a newbie but I have window issues and saw this post so I had to ask...
Old Jan 11, 2017 | 01:26 PM
  #39
gerrymoe's Avatar
gerrymoe
Nope it found a home
Old Jun 25, 2017 | 10:06 AM
  #40
JohnCoruna's Avatar
JohnCoruna
Hi. Sure, check out https://www.nu-relics.com
Just be careful if your door is keeping the vents or you got single glass windows. Then what kind of switches you would like to pick.
Maybe on eBay or Amazon you can get a better price, with some patience and no rush. I bought this nu-relics kit for my 1952 F3 Ford truck and it is a direct fit install. Great build no anoying noise from the little motor. The only thing I did not like much are the power switches as they come in cheap plastic chrome... should be metal instead... Regards
jackstar
May 13, 2017 08:23 PM
throwdown
Mar 2, 2009 10:24 AM
Okiedokie
Dec 15, 2008 10:33 PM
ramblemutt
Jul 26, 2008 11:33 PM
