Does the 6oh really love fresh air that much?
I recently did the 2011 front end conversion and took it for a shake test to see how everything would react. I took the flap off that's by the stock intake and now there's nothing blocking the air, so I know that a ton of air is coming in and I have a ram air hood. Took it for 20 mile drive and check everything, then I decided to jump on the highway to find out if I had everything bolted down tight. Granted, I'm totally stock besides the blue spring, but I was easily able to bury the speedometer and when I was pulling out of a parking lot, I stomped and the rear tires broke traction. Which put me sideways heading to the sidewalk. Before I did the conversion, it didn't want to get out of its own way. For the speedometer, I believe I need to check it with my GPS because I couldn't had been doing a 100+mph. It's very hard to believe that with that much fresh air coming in, it made that much of a difference. What you do you think?
Yes. With the 05 grille, I feel that the grille restricted the air flow and a flap that mounted along the radiator blocked it. The 11 grille is wide open, making it perfect for the 6oh to breathe.
Just so everyone is on the same page here's a link to his build. I often consider the swap myself and I'm sure others do to so here you go.
excursion-2011-exterior-conversion-hwybee22-project-build
It's not that the conversion increased horsepower, but the huge amount of air that I get. Unless my speedometer was hugely off, I was well pass 100mph and reached 90mph quickly. I've played around with it, but it's never burned the tires like it did. Also, I'm guessing the flap by the intake was blocking the air flow, because when I was pulling the front end off, I noticed that the flap covering the hole for the intake and knew that couldn't be good.
