1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
5.4l 3v Timing Issues
Old 08-12-2016, 03:46 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
I bought a 06 Navigator with slight roughness and 2 codes and dealership diagnosed cam timing skipped. Did some searching and reading and found out these have problems with cam phasers and VCT solenoids (sounds like a diesel idling) and/or guides wearing out and chain skipping a sprocket but still running albeit not as smooth nor powerful. The dealership said my phasers and solenoids are good at this point.
Anyone here have any issues or experience with these? I am planning on finding someone to do the chains, guides, tensioners, water and oil pump and see how that goes. Many just put in a new rebuilt long block but I like to see if this will cure the problem.
Old 08-13-2016, 10:24 PM
r2millers's Avatar
r2millers
r2millers is offline
You tube is your friend. Lots of videos to review on this topic.
Here's a 4 part series that will help.
Old 08-19-2016, 01:11 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,193 Likes on 942 Posts
When the driver side cam phaser went bad on my '05 Navi the chain on that side jumped a tooth. When I replaced the phaser I still had a driver side phaser position error. OnceI found an app that could read actual camshaft position I saw exactly what the issue was. If I had the app before replacing the phaser I would have known to fix the cam position too. Two more tries I am still going strong with no issues.
SuperDad
01-10-2019 07:18 AM
greatgreens
1999 to 2016 Super Duty
02-06-2018 02:42 PM
Jaime Roth
Modular V8 (4.6L, 5.4L)
06-05-2016 01:20 AM
akorcovelos
11-09-2015 09:40 AM
tapnuout1
10-28-2013 09:44 PM
Quick Reply: 5.4l 3v Timing Issues
