2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
07 expedition timing cam problem
Old Oct 28, 2013 | 09:44 PM
tapnuout1's Avatar
tapnuout1
I have a 07 expedition that broke a timing chain. I tore it all down the last few days, today putting it back together ran into a problem with the timing marks being off.
The cam phasers (not changed) are not in the position that I have read they should be in. The driver side looks good about 12 o'clock but the passanger side (broken chain side) is at about 10-1030.
I put the chain on the drivers side and all the timing links lined up. on the passenger side the double link is at about 1130. So the timing links are not lined up on the cam.I have the crank key at 12 o'clock which has the dimple at 7 o'clock.
The car did run for a little bit before I discovered the broken chain, did that affect my passenger cam? Looking at the lobs on the cam they appear to be in the correct position.
Thanks for any help given.
greatgreens
Feb 6, 2018 02:42 PM
Jaime Roth
Modular V8 (4.6L, 5.4L)
Jun 5, 2016 01:20 AM
Jam21
Jan 23, 2012 10:44 PM
nikwave
16
Aug 1, 2011 05:52 PM
