Distributor bolt frustration
Old Aug 12, 2016 | 04:31 PM
FuzzFace2's Avatar
FuzzFace2
Sometimes it is best to walk away for a day or 2 then get at it again.
I think it is time to find a tap and being vary careful clean the threads.
Maybe before you chase the threads take a can of air like used to on computers unless you have air and blow out any dirt and crap in the hole. Then run the tap down to clean it and blow it out again.
Dave ----
Old Aug 12, 2016 | 04:46 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I second Dave on the break ... A different frame of mind can always help!
If you get a Starter tap (tapered end), and gently work in it by hand keeping it straight as you keep slowly working it in will increase your chance of getting it back into the original threads.
Only turn it with a handle if you know you are in the original threads ... Be careful, be diligent.
-Enjoy
fh : )_~
Old Aug 12, 2016 | 05:05 PM
FuzzFace2's Avatar
FuzzFace2
-Enjoy
fh : )_~
Yep 1/8th or even 1/16th a turn in at a time and then back out.
And be vary careful as the tap can break easily and then you would be screwed big time.
Dave ----
Old Aug 12, 2016 | 05:40 PM
kr98664's Avatar
kr98664
I second Festus' second of Dave. Does that make it squared? Or would it just be a third?
Also, have you tried a different bolt? I haven't seen that mentioned yet.
slowrollin93
Mar 9, 2007 10:10 AM
bcsbadboys
Nov 20, 2006 01:57 PM
snipa
Nov 17, 2004 01:05 PM
faroffthetrack
Apr 23, 2004 11:21 PM
garageinc2001
1983 - 2012 Ranger & B-Series
Jul 25, 2003 10:54 AM
