AC Drain
Old Aug 10, 2016 | 06:18 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
AC Drain
Where is the best access to clean out AC drain. Water dripping in cab.
Old Aug 10, 2016 | 06:26 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
It is hard to describe... A small hole/port above the passenger side leaf spring slightly to the rear of the spring mount about half way up the engine bay at the bottom of the evaporator housing.
Looking for pictures...
Old Aug 10, 2016 | 07:08 PM
Whitey Ford
Thanks found it. Ran a hose up the drain but it is still slightly leaking in cab. Coming out of drain pretty good?
Old Aug 10, 2016 | 07:14 PM
AllaboutMPG's Avatar
AllaboutMPG
Pic of drain hole
Old Aug 10, 2016 | 07:16 PM
AllaboutMPG
Oh well. not fast enough. May need to let it drain for a while. May have a good build up. Don't know if you can get a shop vac hose up there but worth a try to get it cleaned out
Old Aug 10, 2016 | 07:34 PM
Sous's Avatar
Sous
FTE Emeritus
It should come out quick steadily. I had ran the hose on the evaporator while cleaning it recently and the water was coming out of the drain very quickly.
Old Aug 11, 2016 | 02:21 AM
Whitey Ford
Is there a good way to get to evap pan and the beginning of drain fairly easy?
Old Aug 11, 2016 | 05:15 AM
dn29626's Avatar
dn29626
I do not have an issue, but it would be nice to flush it out at as a maintenance effort.
Old Aug 11, 2016 | 08:30 AM
Sous's Avatar
Sous
FTE Emeritus
I would not say quick or easy, but it can be done. Thanks to our FTE brother AllaboutMPG he cracked the nut for us. I plan to do this during my winter modfest part 2.
Details are below.
https://www.ford-trucks.com/forums/1...stem-seal.html
Old Aug 11, 2016 | 09:23 AM
Whitey Ford
Details are below.
Maybe I can address the drain issue through the blower hole?
Old Aug 11, 2016 | 09:39 AM
Sous's Avatar
Sous
FTE Emeritus
You won't be able to get access to the drain hole at the bottom of the evaporator housing through the blower hole. I could barely get my hand in there to clean the fins on that side with the blower out. Also, the evaporator coil is up against the housing on the passenger side and I think the drain hole is closer to the drivers side and at the bottom. You cannot even see the drain hole, let alone get access to it.
Although, with the instructions AllaboutMPG gave us you can thoroughly clean the coil fins and clean the drain blockage. It will probably take a couple of hours, but your efforts will be paid in a dry cabin floor and probably cooler and stronger air into the cabin.
Old Aug 11, 2016 | 02:39 PM
Bonanza35's Avatar
Bonanza35
Sure it not the heater core leaking? Unless you did the air mod you have coolant in the heater core when the air is on. So it could be either or I would guess. Let us know what fix fix's your problem.
Old Aug 11, 2016 | 04:21 PM
Whitey Ford
The liquid is clear not ELC.
Old Aug 11, 2016 | 08:18 PM
Bonanza35's Avatar
Bonanza35
Not a door seal also? That's good to know.
Old Aug 12, 2016 | 04:16 AM
Whitey Ford
Only drips after AC being on for 5 minutes or so. I plan to put a 90 on the end of the drain. The engine fan puts pressure and restricts the flow coming out. The 90 will keep that from happening and it will direct the flow better and stop the water from being blow everywhere.
