Fuel pump
Old Aug 7, 2016 | 10:21 AM
kylea1627's Avatar
kylea1627
Fuel pump
Just bought 69 f250. Is this a pic of the fuel pump should the rubber hose and metal one be hooked up to something?
Old Aug 7, 2016 | 11:29 AM
greasy rider's Avatar
greasy rider
Well, on my 71, the metal goes to carb and the rubber to gas tank.
Old Aug 7, 2016 | 12:06 PM
351Cleveland C4's Avatar
351Cleveland C4
Uh... yeah! A fuel pump can't pump if it's not hooked up to anything. But obviously someone bypassed it and unhooked it. Probably because it went bad. My advice is to rip out whatever electric junk they rigged up and use a new mechanical pump.
Old Aug 8, 2016 | 01:37 AM
GaryKip's Avatar
GaryKip
If you decide to keep using the electric pump, take off the old pump (in the picture) and put a cover plate over the hole. (You can get them at local auto parts stores or Summit) Personally, I prefer electric over the old mechanical pumps. I had one in my 69 F350 and the new owner says it still working fine.
Old Aug 8, 2016 | 03:32 AM
whiskey runner's Avatar
whiskey runner
i like having a electric inline pump near the tank (for a backup and priming when ya run outta fuel)..but i like to install a new manual pump and rubber line at the frame both frt. and rear..
Old Aug 8, 2016 | 09:40 PM
kylea1627's Avatar
kylea1627
How do you do this? Do you just run some Y splitters on the line or something?
Old Aug 8, 2016 | 09:52 PM
whiskey runner
i just run a inline elec. fuel pump using a toggle switch under the dash.. the manual pump will draw thru the inline electric pump.. at least all the ones i have done would
Old Aug 8, 2016 | 09:55 PM
kylea1627's Avatar
kylea1627
So you just run lines from the electronic pump to the manual pump?
Old Aug 8, 2016 | 10:24 PM
whiskey runner
yes.. the line from the tank..to a inline filter then to the elec. fuel pump.. then to the manual pump.. then up to the carb
Old Aug 8, 2016 | 10:37 PM
351Cleveland C4
Two pumps is completely unnecessary unless the truck will be sitting for LONG periods of time and you don't want to get under the hood to help start it.
It also will create restriction unless they are both running. Over working the one that is running. And could result in fuel starvation under heavy load.
Even a filter being before the pump is not recommended. (But that can be debated)
There's really no point to have two pumps.
Rusty 57
Apr 19, 2019 08:13 PM
Kansafornia
26
Jul 7, 2018 01:21 PM
jeff7825
Ford Truck Parts for Sale
Jun 3, 2010 07:05 AM
Kwikkordead
52
Mar 17, 2006 02:54 PM
Franklin2
Jun 28, 2002 05:52 PM
