262's Fuel Pump Leaking like a Sieve!
Drip, drip, drip... The fuel pump on my '63 F250 262 isn't looking too good.
Q: Better to rebuild or replace?
If replace, is this NORS #241 pump the right one? Says its for "1962-1963 Ford Light Duty Truck 262 6 Cyl"
Or is a more modern pump available that bolts on?
It would appear - based on further investigation - that Bill (aka "NumberDummy") suggested in another thread to...
And, given a 'behind the seat tank', where did you end up placing the electric pump?
Thx in advance!
"...buy a fuel pump block off plate from a parts store and an electric pump. Install the pump as close as possible to the fuel tank as it's a pusher."
With that in mind... Has anyone done this and, if so, which pump did you select, why and how is that working for you? And, given a 'behind the seat tank', where did you end up placing the electric pump?
Thx in advance!
Thx in advance!
Thx in advance!
Personally, I would either find a new mechanical pump for yours, or the parts to rebuild it.
Some of you will notice there's no line out from the pump. Reason: I sort of destroyed it while extracting the pump yesterday... That's my last item to address prior to testing and "relaunch"; likely tomorrow.
Note: I ran compression on the pump and everything looks solid. Other than significant cleaning I replaced 2 gaskets and a spring. Both gaskets looked pretty bad and either could've been my leak culprit.
Again, more to follow...
I did, but... the pics were after dark and so blurry as to be indistinguishable. I've not posted them.
Internals all looked and manually performed great. The top gasket for the chamber where the in-out plungers are exposed was noticeably deteriorated so I cut a new one; as was the main engine gasket. It too got a new cut gasket.
Apologies on the pics. Wish I'd taken better images.
So the initial gaskets didn't seal.
Then the attempt to reseat and add Permatex #3 didn't seal.
So, I ripped it apart (again) and reset gaskets with Permatex "The Right Stuff" and, well, it would appear to be holding so far; kinda like me with my breath until I can say the seals are solid...
Nevertheless, while apart, I took more pics:
In the second pic there is a partial ring clearly visible from where the plunger metal center must be striking the bottom of the upper chamber. Not sure how concerned I should be about that as it's likely been doing so for almost as long as I've been alive and still seems to be working fine?
