Adding 2nd fuel tank back in
Old Aug 6, 2016 | 09:46 PM
TexanAmmo's Avatar
TexanAmmo
Hey all
It's time I start doing research a bit earlier than when I'm ready to tackle a project. I'm wasting more time waiting on parts to come in the mail in between stages of repair & maintenance than I am on anything else. I'll try to get ahead of it this time.
I want to add the 2nd tank back into our F-350. The PO had taken the tank off a LONG time ago, so I am guessing he's been driving around as an occasional use ranch truck for 6+ years with it gone. He did have it very well sealed in heavy plastic & duct taped shut.
Here are a couple pics after I got it out
Rear fuel lines
And another different angle on one of the pieces
Rear fuel lines 2
The spare tire was missing when I bought it and the 2nd tank itself was long gone along with the two metal support straps. So the fun work of getting anything out is already done.
I was hoping I would find the sending unit at least but no joy.
So, what am I going to need? I made some selections here based on my limited knowledge. Please critique & make recommendations as appropriate.
- tank w/ gasket & locking ring $83 + $30 S/H
- fuel pump / sending unit assembly $68 with $0 S/H
- tank straps & nuts/bolts $23 + S/H
I found a kit of tank / pump / sending / straps for $178 including shipping
I like that especially if it comes assembled.
- electrical connectors?
- replacements for any of the hoses?
- is that old brown cylinder an inline filter?
- replacement filler tube?
- any other gaskets / seals etc?
The filler tube from the body wall is ancient but appears to not be crumbling. Not sure where it has to connect to quite yet so I can't determine its suitability re: length.
Tools
- fuel line disconnect tool in case I have to detach again. What size do I need?
I'd love to get parts recommendations as well as parts vendors recommendations. If you provide a link I'll check it out.
Anything else I might need? I have no idea if the tank switch in the cab actually toggles, but the truck did run fine on the front tank when switched to that one.
Old Aug 7, 2016 | 08:05 AM
subford's Avatar
subford
That depends on the one in the photo, if you can clean it up. Also use dielectric grease on the connection.
No it is the "Roll Over/Vapor" valve.
Tools
Your truck uses a screw driver to pry out the clip and then you pull it off.
But at the engine you can use these:
Old Aug 7, 2016 | 08:22 AM
Conanski's Avatar
Conanski
What year is the truck? If it is an '89 or earlier that is the correct FDM but if it's a '90 or later it's not.
Old Aug 7, 2016 | 10:30 AM
TexanAmmo's Avatar
TexanAmmo
it is an 89 manufactured in April in Canada.
Old Aug 8, 2016 | 07:17 PM
TexanAmmo's Avatar
TexanAmmo
Here's a better photo of the connector itself. It is damaged/broken on the side.
fuel pump connector
What is this part called? Are the rubber stubs on the wires designed to come out and I can just replace the plastic part?
Old Aug 8, 2016 | 07:21 PM
TexanAmmo's Avatar
TexanAmmo
Also, the OD of the fuel lines measured .333" with my micrometer. I'm gonna take a stab that means my fuel lines are 1/4" line since 5/16" would have an ID of 0.3125"
Old Aug 8, 2016 | 07:25 PM
subford's Avatar
subford
There is a lot of sources for the plug. Just google WPT-454:
Old Aug 8, 2016 | 07:49 PM
Conanski's Avatar
Conanski
I pretty sure the send and return lines are different sizes.
Old Aug 8, 2016 | 08:20 PM
TexanAmmo's Avatar
TexanAmmo
@Conanski
Good point. I'll make sure to measure both.
Old Aug 8, 2016 | 08:21 PM
TexanAmmo's Avatar
TexanAmmo
I also found a really helpful video for this process. It's for the front tank but it shows the sending unit, electronics, pump etc in detail. Adding it here for my reference.
fp_5
Oct 24, 2021 12:07 AM
blue76
Jul 2, 2016 06:16 PM
hubler13f
May 8, 2016 11:20 PM
zephyr78
Jul 16, 2012 08:55 PM
abranz
Dec 4, 2010 08:51 PM
