215 spark plug question
Old Aug 6, 2016 | 09:26 PM
pholmes350's Avatar
pholmes350
Deciding on a spark plug for the 215. I would like to use the Iridium plugs but not sure which ones fit. Planning on using an HEI or Duraspark II dist. out of a 300 with an MSD 6A so it should be a hot spark which is why I am second guessing using the stock copper core plugs.
Anyone have experience with the Iridiums in the old sixes?
Old Aug 6, 2016 | 09:45 PM
Tedster9's Avatar
Tedster9
Copper core plugs should work fine, HEI runs into problems with solid wires, I'm told though. Just use spiral wound type suppression wires.
Old Aug 6, 2016 | 10:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
With 7:1 compression, not likely you will need a hot spark under any conditions. Are you just using the HEI to trigger the MSD?
Old Aug 6, 2016 | 10:22 PM
toby tough's Avatar
toby tough
My BIL had put the iridium plugs in his Jetta before my daughter bought it. 3 years old and the electrodes were wore down to where there was hardly anything left. Almost 5 bucks a piece. Not worth the money.
Old Aug 6, 2016 | 11:23 PM
pholmes350's Avatar
pholmes350
From what I've read I think I can use the MSD in place of the Ford module if I go the Duraspark route. I may be wrong on this tho.
Old Aug 7, 2016 | 12:25 PM
CBeav's Avatar
CBeav
No need to go crazy on a low compression engine. However... the Load-a-matic advance unit leaves a lot to be desired. A distributor from a later model 300 can be modified to fit and introduce centrifugal advance. If you're the handy sort it isn't very difficult, see: Help with 215 OHV I6 2x1 set up - Page 2 - The Ford Barn Likewise the iridium plugs, just overkill on an old, carbureted, low compression engine. The plugs will foul out long before they wear out. No amount of spark can prevent that, especially on a straight six with a single, antique carb (read: two fat cylinders, two lean cylinders, two just right cylinders - if you're lucky.)
71f100360
May 31, 2017 03:37 PM
garysorenson
31
Jul 19, 2008 11:23 PM
robbiecox6
1983 - 2012 Ranger & B-Series
Jul 11, 2006 06:12 AM
bizarro
Bronco II
Jan 5, 2005 08:15 PM
tw
Electrical Systems/Wiring
Mar 18, 2003 01:37 PM
