rearend
Old Aug 5, 2016 | 09:57 AM
ladelld33's Avatar
ladelld33
rearend
so my 84 f150 has an open diff with 3.73 gears and i don't like that it's an open diff. what should i put in there a locker, LSD or what?? now i do tow a small utility trailer with lawn equipment or just stuff for people from time to time i just don't want to get stuck in someone's back yard or my own.
Old Aug 5, 2016 | 10:51 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Got money ... New Locker's or LSD's are not cheap. You are looking at $600 or more!
Personally, I'd stick a Eaton Tru-Trac in it.
-Enjoy
fh : )_~
Old Aug 5, 2016 | 11:28 AM
ladelld33's Avatar
ladelld33
hey i don't have a car payment so i'm not worried about the price. i'd been looking at the tru-trac too! this truck will hopefully stay in the family long after i'm gone my 17 yr old daughter wants it when i'm done with it.
Old Aug 5, 2016 | 11:43 AM
Nothing Special's Avatar
Nothing Special
Here's a link to a thread I have in the Off-Road forum on the pros and cons of different traction aiding differentials: https://www.ford-trucks.com/forums/1...l#post15935996. A lot of info there (if you like drinking from a fire hose!)
Personally, if it was me I'd put a lunchbox locker in it. It's cheap and very effective. The main downside is that it has some handling quirks that I might not want to make teenage drivers (or my wife) deal with. But I've driven rear locker-equipped vehicles on the road (including in the snow) and I'm willing to put up with the quirks for the positive performance.
The other downside is that lockers are significantly less than ideal for towing. They make it very hard to get started around a corner without a lot of tire squealing. But for the light trailers than an F-150 should be towing I'd still go with a lunchbox locker.
If you want to avoid those downsides, I'd definitely go with a Truetrac.
Or if you want a locker but want to spend more money than a lunchbox, a full-carrier automatic locker (like a Detroit) is certainly stronger (but a lunchbox will generally hold up fine in most applications), or a selectable locker (like an ARB) can give you the best of both worlds, but with the hassle of having to turn it on and off as you need it to be there or not.
Old Aug 5, 2016 | 12:14 PM
Festus Hagen
Methanoholic
Then I would use the Eaton True Trac.
-Enjoy
fh : )_~
carl2591
Jul 9, 2017 05:21 PM
NCMillwright
2009 - 2014 F150
Dec 29, 2015 08:17 PM
easyridin
44
Nov 21, 2015 07:03 AM
Gettysburg150
Mar 20, 2013 09:19 AM
78firestarter
Nov 12, 2006 12:03 PM
