Educational Project Ideas
Old Aug 2, 2016 | 08:18 PM
Boilermaker1994's Avatar
Boilermaker1994
Hey guys, I picked up a 99 f-250 diesel a few months ago as a project truck to learn mechanics. I'm a senior in engineering looking to get into the automotive performance industry and most of the companies I interviewed suggested I get some experience. The truck so far has a cold air intake, 6 position tune, lift kit, all new sound system, exhaust, and a bunch of small less complicated things. My question to you all is this: What other improvements to the truck (handling, power, etc) could someone who is reasonably handy but not a mechanic by any means do that would be of educational value? I'm thinking about adding an anti-sway bar to the rear and maybe some things like that, and maybe when I get more comfortable doing some work to the turbo/engine. Any input would be greatly appreciated. Thanks!
Clark
Old Aug 2, 2016 | 08:53 PM
knottyrope's Avatar
knottyrope
design a 600 hp motor
make a better dipstick seal on the oil pan
improve the steering so it handles like on rails with no slop
Old Aug 2, 2016 | 08:58 PM
Boilermaker1994
Haha thanks, I didn't mean things I could engineer as much as performance modifications and all that that would get me more experience and a better understanding of how a truck works.
Old Aug 2, 2016 | 09:13 PM
knottyrope's Avatar
knottyrope
I learned a lot by fixing stuff. then apply what I know what works.
There isn't much I cant fix unless I don't have the tool
Old Aug 3, 2016 | 02:08 AM
Tugly's Avatar
Tugly
Educational - OBDII tools (link in my signature). It doesn't do anything for more power, but it helps with understanding what's going on in there, plus it give a measurable baseline and progress chart with each mod. I was surprised to see a measurable change in stock boost behavior just by changing the exhaust from 3 1/2" to 4" (with the red line mod already in place).
Old Aug 3, 2016 | 04:48 PM
roostercrows's Avatar
roostercrows
Ok I've seen it twice now.....whats the red line mod?
Old Aug 3, 2016 | 05:36 PM
z31freakify's Avatar
z31freakify
Removing the red line from the turbo's waste gate and capping that line, all it does is prevent the waste gate from opening thus not loosing boost.
Old Aug 3, 2016 | 05:46 PM
Jaime74656's Avatar
Jaime74656
More educational- torque pro link in my signature (if it doesn't post on my phone I will add it in), similar to Rich's post but more information on the app and getting started with it to scan/monitor your trucks health
Old Aug 3, 2016 | 05:49 PM
coax9952's Avatar
coax9952
And crack the Seal on your wallet......
Old Aug 3, 2016 | 06:16 PM
roostercrows
Is there any danger in doing the red line mod? And if not is there a point having the wastegate?
Old Aug 3, 2016 | 06:28 PM
carguy3j's Avatar
carguy3j
The wastegate will still open, based on the spring tension in the little "pod". The red line mod just makes sure it doesn't start to open too early; something known as boost creep.
The red line, via a pcm controlled solenoid, directs manifold pressurized air ( "boost pressure") to that canister, to give it a little "helping hand" beyond just what the spring tension provides. It is know to cause the wastegate to partially open much too early, bleeding off boost pressure.
Old Aug 3, 2016 | 08:06 PM
Bonanza35's Avatar
Bonanza35
All good suggestions, but if you really wanted to learn something you should of bought a 6.0L instead. Then you could fix something that really breaks down. Our 7.3L are pretty safe bets. And you can get a lot more power out of the 6.0L for less money if get all the problems are fixed first.
Old Aug 3, 2016 | 08:13 PM
roostercrows
Thanks guys for answering my questions.
Sorry for hi-jacking the thread....
Old Aug 3, 2016 | 09:42 PM
Jaime74656's Avatar
Jaime74656
posting to add link to torque pro FAQ (check my sig on this post)
pspc271
Mar 15, 2018 03:20 PM
Ryanmays80
6.7L Power Stroke Diesel
18
Aug 26, 2016 07:33 PM
EPI-911
May 5, 2014 11:00 AM
Dxtryng
Dec 26, 2010 05:47 PM
Agemenon
25
Oct 1, 2006 02:03 PM
