I spent most all day trying to bleed the brakes on this thing. I used a vacuum pump bleeder system to start with......It seemed to slow plus having to fight to keep the tubing on tight so I could tell about air bubbles. But I did bleed all 5 locations .
wound up with a half brake petal that would slowly go to the floor.
Next came the Qt. bottle and a single line and pushing the brake petal myself, did all 5 again ....now got 3/4 petal that slowly sinks to the floor
I can give the brake petal a few short quick pumps and get all most a full petal that still slowly goes to the floor.
The truck is in time out.....today so my body can recover just a little.
I don't think there is a place on me that does not hurt right now.
What is next guys................I vote Role back .
Never done the gravity bleed, is there any thing special about it
How much do you open the bleed screw, do you try to catch the fluid. do you put any type of hose on the bleed screw.
How long to do you leave it open and do you bleed everything the same way
RR
LR
Valve
RF
LF
Everything I have is sore.....elbows, knees, hips, shoulders, and back bone . Been a long time since I have had to crawl around on my knees and elbows on the ground
I've never bleed the rabs or whatever you call it but I follow the rest of your order listed. I crack open the bleed screw and let it drip watching the flow. You will see a bubble once in awhile and I tap the caliper while I watch. I only do this for ten-fifteen seconds and move onto the next one. I don't catch the fluid or put a hose on it. I'll walk away for an hour or so then go back and without opening up the bleed screw tap the caliper to loosen up the bubbles. Repeat a few times, its a long slow process but I have had good luck with getting a good strong pedal this way when 'normal' bleeding doesn't work. I've been told many times on this forum I'm full of it but when it works, it works !
That is with the new master cylinder and booster...I have had that in for 3 or 4 days now
When I took out the new booster and was trying to put it back after putting a gasket sealer between the fire wall and the booster. I spent 5+ hrs trying to get the booster back in. Then thought about connecting the old master cylinder back to the booster.
10 min. later I had the booster back in place. How stupid can I get.......LOL
It will take me 2 days just to clean that area....then figure out how the dang thing comes out
