1. Only the rears seem to be working. I've adjusted the fronts til here's slight contact between shoes and drums.
2. When I depress the pedal, sometimes it will start to stop, and then the pedal will release and go further to the floor.
I lent it out to a friend for a while and when he returned it he said he had replaced the brakes. I tore into it and everything looked correct. What the heck is going on here?
Cylinders are new all the way around. The one thing I did when I put in the front cylinders is bled them by just letting them bleed. I just opened up the valve and let the fluid flow out (with a small hose on the valve.) Could that be the problem?
