Air Injection removal problem.
Old Jul 31, 2016 | 08:10 PM
speedemon1084's Avatar
speedemon1084
I have searched the threads and can't find the answer I am looking for. I am in process of bypassing the air injection on my 96 F250 5.8. I am having problems getting a wrench or anything on the backside of the manifold to take that hose off. Any suggestions?
Old Jul 31, 2016 | 08:18 PM
85e150's Avatar
85e150
JMO but on a '96 it's probably best left alone. OBDII O2 sensor is somewhere downstream of that isn't it? Even OBDI could get a CEL out of it.
Can you come up from below with any more room or visibility?
Old Jul 31, 2016 | 08:34 PM
speedemon1084
96 250 is still OBD1. O2 sensor is just in front of where the cat used to be. Trying to come from underneath the oil pan is in the way.
Old Aug 1, 2016 | 07:38 PM
speedemon1084
The only thing I can think of that I haven't tried yet is to cut the head off of the wrench. Maybe that will give me the room?
Old Aug 6, 2016 | 08:52 PM
speedemon1084
Thought I had it figured out, I was wrong, as usual.
Old Aug 7, 2016 | 10:07 AM
Scndsin's Avatar
Scndsin
I'm not familiar with the back of a 96 head AIR set up. Could you take a pic. There are so many variations its hard to advise & no one who is is speaking.
On the back of my 94 5.8 was a block attacked to the cross pipe & held down by a single, don't know, 3/8ths? small head bolt. Maybe 11-12 MM (you never can tell what's there)
Under the block is a 5/8ths, 11 TPI (threads per inch or "coarse") hole you can plug with the appropriate size bolt, or aftermarket plug. Some use a copper washer.
Hope this helps.
Old Aug 7, 2016 | 10:28 AM
speedemon1084
It doesn't bolt to the back of the head. It bolts to the exhaust manifold, jus before it turns down and connects the the exhaust pipes. I requires an 1 1/4 wrench.
Old Aug 7, 2016 | 11:55 AM
Scndsin's Avatar
Scndsin
There are O2 sensor sockets & such. Think I used a box wrench on mine last time. Thought you were going elsewhere with what you're attempting.
Blue86
Nov 3, 2011 06:19 PM
r stene
1983 - 2012 Ranger & B-Series
Mar 14, 2011 12:28 AM
64ford
13
Mar 7, 2011 10:18 PM
breakfree
Jul 24, 2006 04:54 PM
