Ordered SCT Flash Tuner
Old Jul 31, 2016 | 05:41 PM
frakchered's Avatar
frakchered
Ok, just ordered a SCT tuner from MPT. I got put 3 extra tunes on there. I was thinking 87 performance tune, 87 tow tune, and 93 race tune.
Anyone got recommendations?
Please don't make this a battle between 5stars, MPT or anyone else.
I intend to keep my truck stock for now and later down the line adding intake and exhaust.
Thanks.
Old Jul 31, 2016 | 08:07 PM
srb1194's Avatar
srb1194
That's exactly what I have with my SCT. I've been happy with both tunes and never used the 93 tune at all. I leave it on the tow tune all the time now. Raises the shift point for first gear and holds that gear at low speed. I like that for everyday driving. Of course I have a 4 speed and you have 6. I'm probably wrong but I think that helps the transmission. Mine is still original. Not bad for the mileage. Good luck to you.
Old Aug 1, 2016 | 08:42 AM
MCDavis's Avatar
MCDavis
Careful with the 93 Performance tunes as the boost is turned up enough to cause spark blowout (the spark itself, not the plug out of the head). Most tuners recommend new plugs gapped down to .028" to avoid this issue.
I personally run a 87 Perf/Tow in my '13 EB and it pulls quite hard, even with the heavier 275/65/20 KO2s and my 3.31 gears. I did a plug change right at 40k miles just to make sure it was good to go.
Old Aug 1, 2016 | 04:47 PM
frakchered's Avatar
frakchered
Thanks for the heads up, like you though, I will most likely stay in the tow tune and the 93 race will just be a once in a blue moon weekend play around thing. I just got the truck, so I do not need to hurt it running the tune all the time, not to mention with a 36 gallon fuel tank I don't need to spend the extra cash on 93 fuel either.
Old Aug 1, 2016 | 06:49 PM
royb's Avatar
royb
I've supercharged many ford motors and never had a problem with spark blow out. I do run a colder plug and slightly gap them down. I've ran 13lbs of boost on pump gas. a datalog will show if you ever have the issue.
Old Aug 1, 2016 | 07:10 PM
MCDavis's Avatar
MCDavis
I'm running 93 octane on the 87 tune. Keeps the knock retard down a bit. Either way, sounds like you're on the right track.
I've logged a few times and the tuner hasn't found any issues yet. It's been attached to the truck for about 9k miles. Currently seeing 19lbs of boost at peak and around 15lbs during regular driving. Apparently the 93 tunes will see 20-21lbs of boost typically.
Old Aug 1, 2016 | 07:55 PM
frakchered's Avatar
frakchered
Good to know. I will look into it once I get my tunes and the flash tuner.
Yeah I had thought about that. I was on the website and they were talking you can run the higher octane with the lower octane tune, you just can't do the opposite as it will retard the timing because of the knock sensor.
Also good to know.
Do both of you keep the flash tuner attach to use as a gauge or do you run different set up for gauges?
I bought the X4 SCT and I am able to use it to keep an eye on some of the readings.
Old Aug 1, 2016 | 08:07 PM
NASSTY's Avatar
NASSTY
No need to keep it attached unless you are data logging.
Old Aug 2, 2016 | 06:01 AM
frakchered's Avatar
frakchered
Is that what I would use running the MPT tunes to help them fine tune there tune should there be any issues?
Old Aug 2, 2016 | 07:10 AM
QwkTrip's Avatar
QwkTrip
Choose a tune you can live with all the time because in reality you'll end up running that tune all the time.
You don't just put in a 93 tune for a Sunday drive and switch back on Monday. It takes 2 tanks of fuel to flush out lower octane fuel and really have 93 on board. That is 1000 miles of driving with your big fuel tank. Each time you flash a file the transmission will feel less refined for a couple days until it relearns your driving style. And 93 race tunes need tight plug gaps - tighter than what you'll run with other tunes, not to mention other supporting mods. Personally, I wouldn't run a 93 race tune on an otherwise stock vehicle.
You data log with a laptop connected to the SCT tuner. You'll need a config file from MPT to capture the data they want to see.
I use a custom 91 tune for everything + downpipes + intercooler + thermostat
Old Aug 2, 2016 | 07:08 PM
frakchered's Avatar
frakchered
good to know. You got a recommendation for another tune? I already want the 87 performance and tow, I will most likely stay in either one of these unless another can be had to play with on 87 octane or on mid grade.
Old Aug 2, 2016 | 09:01 PM
QwkTrip's Avatar
QwkTrip
You shouldn't have to do that. You're still on that SCT tune, aren't you?
Old Aug 3, 2016 | 07:55 AM
MCDavis's Avatar
MCDavis
Negative. Emailed tunes. That SCT canned tune shifted like dog poo. The emailed tune is muchhhhhhh better.
I have noticed that the 87 P/T does run a little happier on the higher octane and the knock retard at full throttle is less drastic. I know I don't have to, but it's a couple bucks a month and I don't mind it.
Wife's ride is 93 octane as required by the manufacturer so it's easy just to hit 93 at the pump regardless of what I'm filling up that day. Hell, I even run my yard equipment on 93...except the Stihl products as they get nothing but MotoMix
Old Aug 4, 2016 | 07:32 AM
frakchered's Avatar
frakchered
Nice, well I know for sure I am going with 87 performance and the 87 tow. I will have to maybe email them to see what I can do as for the 3rd tune. maybe a custom one off or a mix of something.
Old Aug 8, 2016 | 05:20 PM
frakchered's Avatar
frakchered
Wow, so I had been riding a few days on the stock canned tune from SCT. And as MCDavis stated man it shifts like poo. Just got my MPT tunes from James at MPT, loaded my 87-89 Towing Street tune. Thing comes to life. Right off the get go the throttle response is nice, I hit about 16.97PSI on the boost. I like so far. I also got the 87-89 Performance Race, and the 91 Performance Race tune. I may have to try the 87-89 Race tune to see how it is. But so far I like the new feel of the truck.
optikal illushun
2004 - 2008 F150
Feb 15, 2012 07:01 PM
Bigpipes 35
Mar 17, 2011 12:37 PM
Thenewboss
6.2L V8
27
Jan 21, 2011 10:58 AM
TEAM HARD
Modular V10 (6.8l)
18
Nov 12, 2010 08:18 PM
socalpsdowner08
Computer Chips & Tuners
May 18, 2010 11:30 AM
