Transmission flush logic/questions
Old Aug 1, 2016 | 10:01 AM
PSU4ME's Avatar
PSU4ME
Originally Posted by Mark Kovalsky
No, no different than if it were changed frequently.
There are also different gaskets. The only one that fits is the OEM type. It's rubber and fairly thick, with metal inserts. There is also a rubber gasket that is as thin as the cork. It works even worse than the cork one does.
Thank you. by chance do you know who carries the right gasket? Would the dealer have it?
Old Aug 1, 2016 | 10:49 AM
farmert's Avatar
farmert
Originally Posted by fordman67
Get a wix. I believe they have the metal housing shell. I have seen the plastic have issues.
If you have a NAPA store nearby, Wix makes the filters for NAPA.
Old Aug 1, 2016 | 10:58 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, the dealer will have it.
Old Aug 1, 2016 | 11:55 AM
PSU4ME's Avatar
PSU4ME
Thanks, i think i'm good on the filter, just looking for the right gasket.
@Mark, I just got off the phone with Xtreme diesel and while the kit does have a rubber filter in it, i think the dealer might be the best way to go if its needed.
Thanks!
Old Aug 4, 2016 | 04:32 AM
PSU4ME's Avatar
PSU4ME
Hey Mark,
We dropped the pan to take a look at the gasket and i'm glad we did, its in pretty bad shape. To follow your flushing instructions, should we put the pan back up and add the old fluid or can we junk that fluid and just switch the process up a little bit and use this as the first 6 quart flush?
Thanks for your help.
Old Aug 4, 2016 | 06:28 AM
Mark Kovalsky
There is no reason to put the old fluid back in. Once you put the pan back on go to step #3.
Old Aug 4, 2016 | 06:38 AM
PSU4ME's Avatar
PSU4ME
Thank you sir!
Old Oct 21, 2016 | 10:26 AM
mate0o1's Avatar
mate0o1
Mark, Where do I find your tutorial about changing the tranny fluid/filter?
Old Oct 21, 2016 | 05:48 PM
Mark Kovalsky
Right here: Changing ATF Fluid in a E4OD and 4R100 transmission - Ford-Trucks.com
2civicrr
Aug 12, 2013 08:44 PM
diesel_dan
Jul 16, 2013 10:54 PM
ayre
Apr 17, 2013 04:20 PM
79FordBlake
Jan 2, 2010 12:24 AM
mohawk82
Oct 15, 2003 07:21 AM
