DIY Efuel Thread (w/ easy to read parts list)
Old 01-06-2016, 10:40 AM
1994F2507.3L's Avatar
1994F2507.3L
1994F2507.3L is offline
All,
I will be needing to do the e-fuel conversion soon. I plan on doing it after I get my taxes done.... and since its freezing cold and I don't have a whole lot going on I worked up the parts list on a spreadsheet that should be easy to read and follow..... I've noticed no one has really put it together yet in my search for info. This should prove useful to any novice who is coming in wanting to do this. It should be complete as I reviewed quite a few threads regarding this and took away everything I could to make a complete list. I will update when I get everything and attempt to put it together lol anyhow...... let me know what you think of the list.
The total I came up with is around 700.00$. That price does NOT include the edge insight parts
I didn't cut corners or source cheap parts really, most of the fittings are EATON Weatherhead.
Old 01-06-2016, 11:01 AM
AZFX4's Avatar
AZFX4
AZFX4 is offline
So whats the $ total?
Old 01-06-2016, 11:18 AM
1994F2507.3L
700.00$ that price does NOT include the Edge insight parts.
Old 01-07-2016, 08:15 AM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Judging by the picture... if you take $700 + the two edge parts then the total comes to roughly $964.74
Old 01-07-2016, 08:48 AM
AZFX4's Avatar
AZFX4
AZFX4 is offline
So im new to this whole Efuel thing so correct me if im wrong but cant you buy a complete aftermarket setup for less than that?
Old 01-07-2016, 09:11 AM
nossliw's Avatar
nossliw
nossliw is offline
Originally Posted by 1994F2507.3L
All,
I could compile my efuel parts list as well as its fairly easy to go through my summit orders.
Old 01-07-2016, 09:15 AM
nossliw's Avatar
nossliw
nossliw is offline
1000-1200 for a complete kit, plus you get to build it how you want. I did mine all with SS lines and setup a bit different than most and saved probably 300-400$ over what a "cheap" kit cost. Learned a lot along the way too, also aquired a ton of great tools for use down the road.
Old 01-07-2016, 09:20 AM
AZFX4's Avatar
AZFX4
AZFX4 is offline
So whats the difference from an Efuel to something like a Fass or Airdog system? I see those for like $700 so seems like a more cost effective solution. Please correct me if im wrong.
Old 01-07-2016, 01:12 PM
Awitte58's Avatar
Awitte58
Awitte58 is offline
I am not sure where you are finding your numbers, but when I googled 'fass fuel 7.3' and went to the Xtremediesel website.
Just the pump/filter setup is $1000 and the regulator is $140
Aeromotive 11802 Fuel Pump
FASS FPR-1001 Fuel Pressure Regulator
Thoroughbread was similar for the FPR
FASS Fuel Pressure Regulator
Old 01-07-2016, 01:13 PM
Awitte58's Avatar
Awitte58
Awitte58 is offline
I agree with you that $700 is pretty high for DIY, but I don't recall there being a full complete kit (wiring, pump, regulator, fuel lines, EVERYTHING) available for that price.
I recall it being $1000+.
Old 01-07-2016, 01:40 PM
AZFX4's Avatar
AZFX4
AZFX4 is offline
I guess the only one I looked at was the Airdog $719
PureFlow AirDog II Air/Fuel Separation System DF-165 Powerstroke 7.3L
I guess my question is still, is there a difference besides price?
Old 01-07-2016, 02:56 PM
Bob_T's Avatar
Bob_T
Bob_T is offline
Nik, could you post a picture or two of your SS line system? Or a link if you have an existing thread? I searched but didn't find one.
Thanks!
Old 01-07-2016, 03:00 PM
nossliw's Avatar
nossliw
nossliw is offline
Thanks!
https://www.ford-trucks.com/forums/1...thread-36.html Couple pics in there...
here are a couple more...
Old 01-07-2016, 04:24 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
I would never diy a fuel system on these trucks again. I have between 700 and 800 in mine, and a lot of headaches. Almost anything I needed I had to order. I live in the middle of nowhere and it was a pita to get all of my parts. It can be done quite a bit cheaper than that, but then you are using cheap parts. Not my style.
If I were doing it again, I'd spend a little more and buy a well put together kit. JMO of course.
Old 01-07-2016, 05:40 PM
Bob_T's Avatar
Bob_T
Bob_T is offline
Thanks, looks like a very clean installation and it looks like you accomplished one of my goals which is to avoid having the filters exposed and vulnerable to rocks and other hazards.
Darin, I know what you are talking about. I'm in the middle of kluging together my own system, although I cheated and bought parts of a kit. I didn't realize what I was getting into and I haven't even started on the electrical part yet.
Quick Reply: DIY Efuel Thread (w/ easy to read parts list)
