Stuck Spark Plugs
Old Aug 22, 2016 | 02:48 PM
Brian1971f100's Avatar
Brian1971f100
After looking at the plug I think maybe you had the wrong sized socket. I'm sure these old engines didn't use metric sizes. Metric and US sizes can be close but never the same. Hope you have better luck on the remaining 5
Old Aug 22, 2016 | 02:54 PM
CougarJohn's Avatar
CougarJohn
That is good news. You need a deep 13/16 socket. With that and the breaker bar, the plugs will break.
Semper Fi
Old Aug 22, 2016 | 08:46 PM
RORZA's Avatar
RORZA
Look up "hotrodreference.com" General information side bar has the solution to stud/bolt removal. May be of some use to somebody. Blind in one eye DEAF in one ear. Trying to give help. Not too worried about politically correctness. Not trying to insult fellow members on this excellent site.
Old Aug 22, 2016 | 08:50 PM
KsHighboy's Avatar
KsHighboy
ATF mixed with acetone is a good penetrant! Might try it. Soak em and let me set a few days.
Old Aug 22, 2016 | 11:18 PM
351Cleveland C4's Avatar
351Cleveland C4
If you're having trouble gripping it, get a cheap 12point 19mm socket and smash it on with a hammer. Extract plug and either scrap the whole works or drive the plug out and keep the socket.
Another idea, bust all the porcelain off and weld a larger nut on top of the plug base. The heat will help and the electric current may help bust up the rust on the atomic level.
lasmacgod
Modular V10 (6.8l)
Aug 23, 2010 04:15 PM
crestfallinman
13
Apr 26, 2010 04:43 PM
SuperFord
Sep 10, 2007 08:43 PM
Silnyr
1997 - 2003 F150
May 2, 2005 11:08 PM
Stump Man
1983 - 2012 Ranger & B-Series
Feb 13, 2005 09:55 PM
