New wheels
Old Jul 28, 2016 | 11:11 PM
Dizzo13's Avatar
Dizzo13
New wheels
Hi i have a 1999 ford f250 and i currently have 16" i was looking to upgrade to 18" or 20" but not sure if i should. I use my truck everyday and im out on dirt roads as well as in the city a lot. So i need help in deciding if i should get a bigger rim or not, whats holding me back is i dont know how much it ia going to affect me as far as weight of wheel/tire and suspension wise anyone have any opinions or suggestions?
Old Jul 29, 2016 | 02:05 AM
Ezalycasaid's Avatar
Ezalycasaid
Your wheels aren't really gonna make that much of a weight difference. Your weight comes from your 10ply (load range e) tires. The Steel cords in them are what add up your tire weight. A bigger size tire will ad weight because the cords are now longer to make up the eXtra od added. Also the bigger the wheel the less amount of air volume inside of the same size od tire. So u have less room to air down a little and allow ur tires to obsorb some of the impact. I personally would never go to a 20" wheel. Too expensive and just not a fan of them on these trucks. I personally would go with 17s if u really wanna go any bigger. There cheaper wheels, u can find more variety, and tires are alot easier to find and are cheaper. But that's my 2 cents.
Old Jul 29, 2016 | 06:24 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE
i would stick with the 16 inch tire.
Old Jul 29, 2016 | 09:54 AM
knottyrope's Avatar
knottyrope
if you get bigger rims, get bigger tires
those that run low profile tires always wreck a tire or rim with a pothole since it cant adsorb the shock of it. my brothers Escort GT went through many tires and rims
I have never owned a low profile tire for this reason
Old Jul 29, 2016 | 09:57 AM
JOHN2001's Avatar
JOHN2001
Welcome. The size rims have absolutely nothing with where you drive. You drive city, dirt roads... so. If you go with the same height tire what you will notice a ride quality difference on the street mostly since you'll have less sidewall to absorb the impact.
Old Jul 29, 2016 | 10:25 AM
UcaN's Avatar
UcaN
Price a 20" tire !!!
Now price a 16" tire....!!
You will discover that the 16" is a lot cheaper and the added bonus is they look better. jajaja..... I am not a fan of 20" tire wheel combos but that is just my opinion.
Old Jul 29, 2016 | 10:34 AM
binuya's Avatar
binuya
My opinion is to stay with the 16". To be frank, I don't get this ridiculous trend of 'more wheel and less tire' on vehicles, especially trucks. It ruins your ride, harder on the suspension components, and your expensive wheels are more prone to damage. It's purely cosmetic, and makes no sense to me. You pay more to get less. I don't get it. Sorry for the rant, but just seeing it on the street annoys me.
Old Jul 29, 2016 | 10:49 AM
Tugly's Avatar
Tugly
I'll bring up the less subjective stuff:
Many of the aftermarket 16" rims "fit"... but don't. They sometimes extend out past the body, flinging road onto the body and your mirrors. The other issue is the inside diameter barely clears the front brake calipers. If there is no lip on the rim, then the balancing weights have to go on the inner face of the rim. You can find yourself hearing a "scrape-scrape-scrape" while driving out of the tire bay.
One other thing: Costo (in my area) carries piles of 17" tires - not so much with the 16".
Do your homework, and the decision on the 16" might be made for you.
Old Jul 29, 2016 | 11:38 AM
Dizzo13's Avatar
Dizzo13
Yea i think a 16 in wheel would be better off for me.. i work in theAG industry and im hauling tractors and ag eqipment so i think i should stick with the 16 in wheel
Old Jul 29, 2016 | 03:15 PM
cps's Avatar
cps
I switched to 18" and would never go back. Way more tire selection. slightly shorter sidewall depending on what you buy. less sidewall gives you less tire squirm when you hall heavy. Better handling with a shorter sidewall. thats my opinion.
Roy.
Old Jul 29, 2016 | 07:43 PM
Dizzo13's Avatar
Dizzo13
I forgot to mention i currently have a 2.5 leveling kit on my 99 ford f250 and im running 315/75/r16 i dont know if this makes a difference on weather i should go with 18 or 20 inch wheels
Old Jul 29, 2016 | 10:36 PM
BioHazrdMan's Avatar
BioHazrdMan
Couldn't be happier with my 18's... leveling kit, air bags in rear to keep it level. No rub. I modified front inner fender mud shield thing. Running 35X12.5 18's. Dont know how it would work with stock bumper though....
Old Jul 30, 2016 | 01:57 PM
z31freakify's Avatar
z31freakify
Another Platinum owner and an almost neighbor
Miles Rittenberg
Jan 7, 2018 07:27 PM
JoshC017
All Things Towing
16
Nov 3, 2017 01:23 PM
firefighter1416
Offroad & 4x4
Oct 18, 2010 07:21 AM
xxxcre10xxx
13
Dec 15, 2002 12:13 AM
DannyP
Oct 11, 2000 01:16 PM
