I made a dumb mistake
Old Jul 27, 2016 | 07:30 PM
pweng1's Avatar
pweng1
Ok I did the stupid thing I know better than but I used the 3 jaw puller on a ford harmonic balancer. Ruined the outside pulled it right off. Now I have these questions. What determines which balancer. Can I use a crank and balancer from another same bore and does anyone rebound them or fix them.
Old Jul 27, 2016 | 07:48 PM
Tedster9's Avatar
Tedster9
There are the "Damper Dudes" and the "Damper Doctors" both have online presence and rebuild or core exchange afaik.
This would be the way to go, the damper was lunched anyway after all this time, the rubber bonding is no good.
Old Jul 27, 2016 | 10:50 PM
EBEAR's Avatar
EBEAR
Just need the proper balancer for your engine they are not specific to a particular engine
Old Jul 28, 2016 | 12:21 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Ebear,
Can you elaborate?
Old Jul 28, 2016 | 12:52 PM
EBEAR's Avatar
EBEAR
Don't know what engine you have but for instance my 351 w is a 28 oz imbalance so the flexplate and balancer must also be 28 oz but you can take a balancer off of any 28 oz balanced engine they are not balanced to your specific engine . So you need to find what imbalance your engine has and find a matching balancer . This is for factory balances if you have a internally balanced or custom balanced then you will need the build info . I Hope this helps
Old Jul 28, 2016 | 01:44 PM
bjmayberry2
Got ya. I thought you were talking Y-Blocks. As far as I know all vibration dampers for Y Blocks fit but there may be a difference between car & trucks.
Old Jul 28, 2016 | 06:02 PM
pweng1's Avatar
pweng1
This is for a 1979 ford 302 I have numbers on the balancer. What I thought was if you had like a 223 crank then your balancer went with that crank. Stroke and counter balance size being factors.
Old Jul 28, 2016 | 07:58 PM
CharlieLed's Avatar
CharlieLed
Lots of aftermarket balancers on the market now...I believe I bought the last few from Summit. One thing to be aware of if you go that route, the new solid balancers are not as deep as the OEM units and need a spacer to bring the crank pulley into proper alignment.
Old Jul 28, 2016 | 09:46 PM
EBEAR's Avatar
EBEAR
No if you have a non modified 302 then you can use any 302 balancer and as said must fit your belts and spacing
LRShooting
Large Truck
Mar 20, 2014 08:54 AM
beartracks
Jan 25, 2009 04:14 PM
C-Leigh Racing
Nov 27, 2008 05:11 PM
tHeCoS
1978 - 1996 Big Bronco
Jan 11, 2004 06:05 AM
