Smoke or not smoke?
Old 08-08-2016, 03:53 PM
mcali2's Avatar
mcali2
mcali2 is offline
Smoke or not smoke?
I have noticed before when I started my truck it would smoke for a while until warm I guess but now I don't see any smoke at startup. I guess it could have to do with cold and hot days but the smoke I seen was smoke and not moisture on a cold morning.
Old 08-08-2016, 03:57 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Sounds like you have some bad glow plugs or bad UVCHs
Old 08-08-2016, 07:22 PM
fordpride's Avatar
fordpride
fordpride is offline
Was the smoke white or light blue ?
Old 08-09-2016, 12:02 AM
mcali2's Avatar
mcali2
mcali2 is offline
It was white. I did replace glow plugs but i have done a bunch of stuff since then and did not do any driving while I made all the changes. I find it weird I don't see it any more.
Old 08-09-2016, 06:14 AM
Diesel_Brad
Have you checked the UVCHs and the plugs?
Old 08-09-2016, 08:36 AM
mcali2's Avatar
mcali2
mcali2 is offline
I checked to make sure they are plugged in, I have not tested them yet. I think my post was not clear sorry. The truck runs good. The smoke was after it started. I would have it and now it does not smoke after it starts. It seemed odd to me and was trying to figure out of there could be another issue that may cause it. Perhaps a bad connection like you mentioned.
Old 08-09-2016, 09:25 AM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
That's the nature of the beast, diesels smoke when there cold, cold days make it worse....
Old 08-09-2016, 10:14 AM
pwjackson42's Avatar
pwjackson42
pwjackson42 is offline
If you replaced the glow plugs and are not seeing the smoke now that is good, they are working now. I need new plugs as I get some smoke on a 70 degree day.
Old 08-09-2016, 11:26 AM
fordpride's Avatar
fordpride
I think you fixed the issue with the new gp's and you are over thinking it. Don't worry about it unless is broke
Old 08-10-2016, 07:11 AM
Diesel_Brad
Yes, you have to test them. They are Very common to get overheated from the extreme amps the GPs pull and melt the connectors at the UVCHs, VC gasket and pigtail where it plugs into the VC gasket
PsD007.3
07-21-2009 12:22 PM
Nukkels
04-19-2009 01:35 AM
Eric_F250
15
01-21-2008 11:34 AM
nhill2090
10-15-2007 12:11 PM
97StOkErAcE
10-06-2004 06:55 PM
Quick Reply: Smoke or not smoke?
