Oil Cooler replacement
Old Jul 26, 2016 | 09:47 AM
jkey.bama's Avatar
jkey.bama
Smile Oil Cooler replacement
Ok Guys, I need your thoughts and advice. The vehicle is a 2004 ext. cab F350 dually 4x4 w/4.10 gears.
There is absolutely nothing wrong with the engine. Runs great, deltas great, no complaints. The truck is approaching 150K miles. Nothing wrong, just think 150K is a good time to replace the oil cooler before I start having problems. Do you agree or disagree?
Now the real issue, what else should I do or not do since I'm in oil cooler deep? Turbo cleaning, upgrade? Blue spring upgrade will be done. Not bulletproofed - egr cooler delete? Screen replacement or other HPOP work?
Ficm will be removed, sent to Ed for work & Atlas 40 tune & ficm relay replacement. Flush & replace coolant before or after oil cooler replacement?
Any other thoughts, suggestions and/or advice will be greatly appreciated!
Thanks for the help and Have A Great 6.0 Day Everyday!
Old Jul 26, 2016 | 09:58 AM
Tideman's Avatar
Tideman
Why? If it ain't broke don't fix it. Just keep up with your maintaince. Don't go poking around and create a problem. I understand wanting to work on your truck, it's fun and enjoyable. Go tear into your lawnmower to satisfy the urge. ;-)
Old Jul 26, 2016 | 10:09 AM
jkey.bama's Avatar
jkey.bama
Ok Tideman, I'm also from and returning to Alabama (ROFLMAO). Did you replace the oil cooler, egr delete when you had a problem? What did it cost to utilize the Detroit True Trac 3.73 gears or is it OEM? Do you tow heavy (over 10K lbs.)?
Already rebuilt 2 zero turns (Scag & Grasshopper), push mower & 2 redmax weedeaters (LOL). Thanks & Have A Great Day. Oh yeah, we're gonna win it again, harder to do this year, but it will be done!!!
Old Jul 26, 2016 | 10:42 AM
Tideman's Avatar
Tideman
Got oil in coolant and deleted EGR while in there. Hadn't ever touched it till then. Detroit Tru Track was $1200.00 installed with my help. Probably would have been $900.00 without my help. No I don't tow on a regular basis. Do tow small kubota front end loader and 16' trailer some but that's about it. ROLL-TIDE !!!! What part of Alabama?
Old Jul 26, 2016 | 10:54 AM
jkey.bama's Avatar
jkey.bama
Small town of Parrish, suburb of Jasper, bout 30 miles northwest of B'ham.
Where you at South?
Old Jul 26, 2016 | 11:08 AM
Tideman's Avatar
Tideman
Dothan, got a few friends in and around the Birmingham area. Going to be heading that way the next 4-8 weeks to pick up a 1985 Izuzu diesel pick up that has been in storage for about 20 yrs. That'll keep me from screwing with my 6.0 ;-) for awhile.
Old Jul 26, 2016 | 01:05 PM
Jeff Watts's Avatar
Jeff Watts
Rather than tearing into it with no issues, how's about doing a good coolant flush, adding Fumoto valves, and adding a coolant filter.
Cut the coolant filter open when you change it, and look for sediment and crud. Keep watching your delta, and enjoy the truck.
Old Jul 26, 2016 | 05:55 PM
69cj's Avatar
69cj
If you do a coolant flush just use distilled water. Do not do a chemical flush. You don't have a problem, don't creat one. Don't fix what ain't broken.
Old Jul 27, 2016 | 09:40 AM
jkey.bama's Avatar
jkey.bama
Fumoto valves & coolant filter done. Will do flush. Thanks!!
fyredude
Sep 1, 2014 03:40 PM
Thomas Booth
Nov 7, 2013 05:53 PM
viper29
Apr 9, 2012 10:15 AM
White F250
Mar 14, 2011 09:06 PM
Bordercollie61
Sep 27, 2010 03:10 PM
