Towing engine build
Old Jul 26, 2016 | 03:17 AM
crucialprospect's Avatar
crucialprospect
Thanks for all the insight, is there any real benefit with the performer intake over a port matched stocker? Also, any gains in the higher end hypereutectic versus a cheaper alternative? I'm not trying to cheap out, but it's not exactly what I call a high performance build where all the bells and whistles are required.
Old Jul 26, 2016 | 07:42 AM
kg6mov's Avatar
kg6mov
A lot of performance manifolds will lose some low end torque in favor of high rpm performance, which isn't what you're going for.
Old Jul 26, 2016 | 08:24 AM
Gary Lewis's Avatar
Gary Lewis
There is a significant weight difference between the stock cast iron and aluminum. But, as was said, some aftermarket manifolds are designed more for higher RPM than low-end torque. For instance, Edelbrock makes the Performer that is tuned from idle up, while their Performer RPM is a bit higher in the range. So, if torque is the goal then shop for ones tuned for that.
However, there is a minor disadvantage to aftermarket. Most relocate the carb from stock enough that the throttle bracket/linkage combo doesn't work well. Typically the carb comes back enough that there's slack in the linkage. Edelbrock sells a kit that supposedly fixes that, but in my experience it is a joke. I prefer to mod the factory bracket by sawing it apart, installing a spacer, and welding it back up. But something needs to be done in my opinion.
Old Jul 26, 2016 | 10:42 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have a 460 performer.
Any loss off idle is minimal.
With water and an exhaust crossover in the manifold it warms up much faster than cast iron and probably weighs #50 less.
You shouldn't use a turkey pan gasket with an aluminum intake.
Old Jul 26, 2016 | 02:46 PM
crucialprospect
That's what I've been hearing, weight savings is the biggest gain.
carlmaass
Jul 20, 2011 03:05 PM
rye2842
Jun 1, 2007 09:56 PM
10MPG
Mar 18, 2006 07:51 PM
gt93ford
Mar 3, 2004 05:12 AM
jbulson
19
Dec 30, 2002 10:48 AM
