460 with 8:1 compression
Old Jul 20, 2011 | 09:53 AM
carlmaass's Avatar
carlmaass
Well I looked up the specs for my '77 460. Turns out it only has a 8:1 compression ratio. Ouch! I was hoping for something around 9 or 9:1. It has the stock D3VE-A2A heads.
Is there any way to bump up the comp ratio to give me a little more torque other than milling the heads? I'd rather not mess with the valvetrain angles. I could find some D0VE heads?...Domed pistons?...
This 460 will be an occasional tow/hauler and needs to run on pump gas. I'll throw in an RV cam, but I've read from a few posts that I might not be able to fully utilize a higher performance cam due to the lower comp ratio.
Exhaust porting and headers will also be additions.
Thanks for any advice.
Old Jul 20, 2011 | 10:40 AM
mark a.'s Avatar
mark a.
Milling D3 heads won't raise it enough to make a difference and putting DOVE heads on without zero decking it will probably make it a pinger. One real problen with big blocks is the pistons are way too far in the hole. I used the 6cc dished 88-93 pistons, took .032 off the blocks deck, that put the pistons at around .005-.008 in the hole and milled my D3's to 95cc that made it close to 9.5:1
Old Jul 20, 2011 | 03:05 PM
Thunderbird7480's Avatar
Thunderbird7480
mark is right. Im working on a build and already went through all these numbers my self.
I have a set of D0VE heads in my truck now. The engine is from a '70 Lincoln. I run 91 octane in it just fine with no pings except up steep hills. I would imagine this would be more pronounced if I were towing.
Anyways, the problem with the D0VE heads is that the difference is so drastic. It doesnt just bump the compression a little. My new engine will use the 95cc heads but my pistons are what will get me into the 9.5:1 neighborhood that I am after.
V10man
Dec 30, 2021 10:48 AM
FordFETruck
15
Aug 18, 2014 03:24 PM
Boost-hard
20
Dec 17, 2012 02:33 PM
81f2504x4
Apr 26, 2004 03:10 PM
Superdave
Jul 12, 2003 01:21 AM
