Rear Fuel Line Removal
I am pretty sure it is the quick disconnect type like on the tank. I'll look for a decent picture and post it back here.
EDIT: I am having a hard time finding a picture of the stock setup. Most of the pictures I am seeing have a fuel injector clamp or hose clamp on them now like I have.
You should be using tools like the ones below to remove the disconnect. I suspect that it has a bunch of crud in it and needs a good cleaning as well.
That is not what mine was. I can't find a picture right now but mine was a white 'u' clip, looked like a horseshoe that slides out from the side with a screwdriver and probably breaks, all auto parts stores stock them.
Here's what they look like.
http://shop.advanceautoparts.com/p/n...+line+retainer
They come in white or black depending on what size the line is, mine was white.
I do think you'll find the ones that Sous shows on the tank itself.
early
06-04-2006 10:43 AM
