Fuel line replacement
Old Dec 26, 2012 | 08:01 PM
Hyperryd's Avatar
Hyperryd
Ok, I am stuck. I kinked a fuel line when I took it off. I have the new fuel line, but I can't get the old one to let go. It has some kind of disconnect I haven't seen. It looked simple enough to remove the clip and pull the hard line out. No such luck. I don't want to force them and break something. Is there a special tool or an easy way to separate them?
Old Dec 26, 2012 | 08:07 PM
BLADE35's Avatar
BLADE35
You need the special tool
Old Dec 26, 2012 | 08:12 PM
BLADE35's Avatar
BLADE35
Like one of the cheap ones that go around the line and press into it
like this one its more spendy that the cheapy plastic ones
OEM/Fuel line disconnect tool for GM, Ford and Chrysler (25043) | Line Disconnect Tool | AutoZone.com
Old Dec 26, 2012 | 08:14 PM
BLADE35's Avatar
BLADE35
Here is the cheap plastic ones Im talking about
And Should Work better than the other one I posted
Lisle 37000 Air Conditioning/Fuel Line Disconnect Tool Set : Amazon.com : Automotive
Any cheapy from Auto parts store should work they will probably be Labeled A/C Dissconnect tools
Oreilys or AZ will have them cheap
Old Dec 26, 2012 | 08:16 PM
Hyperryd's Avatar
Hyperryd
You know I saw those earlier today when I was looking for something else.
Thanks.
Yahiko's Avatar
Yahiko
The tool you need is this one
OTC 2 Piece Fuel Line Disconnect Tool Set for Ford Chrysler GM 7361 | eBay
Sean :drink
Old Dec 26, 2012 | 08:17 PM
vloney's Avatar
vloney
This one is what I have. Be careful with them and they'll last forever.
Old Dec 27, 2012 | 08:04 AM
69cj's Avatar
69cj
I've got both the metal and plastic sets. Both work however the metal set does work better with less strain on the operator.
Old Dec 27, 2012 | 08:14 AM
Misky6.0's Avatar
Misky6.0
$9 and eligible for free shipping - nothing I ever need is that cheap!?
This would work on the trans-lines to the radiator as well?
Old Dec 27, 2012 | 08:38 AM
vloney's Avatar
vloney
There is a specific one for that one.
Magister
1983 - 2012 Ranger & B-Series
Dec 2, 2017 06:09 PM
Z06MAN
Aug 16, 2010 08:35 PM
O's Fan Rich
Dec 28, 2009 12:44 PM
Brewbadoob
Dec 5, 2009 05:55 AM
grizz3000
Jul 30, 2007 11:21 PM
