Remove entire motor mount ?
Old Jul 22, 2016 | 09:27 PM
jakeharp's Avatar
jakeharp
Question Remove entire motor mount ?
76/390/c6/4x4
Sorry for the continuous onslaught of potentially lame questions... I hooked up the cherry picker this afternoon and put a little pressure on the block to get a feel for how things were looking .... There is definitely some wiggle at the trans/torque converter/flex plate marriage that indicates it wants to separate. However, there is zero budge from the front of the motor and I got to thinking, should I be taking the entire motor mount off, I obviously have the nut off that comes thru the steel motor mount which the stud slides thru, but that thing hasn't moved a hair I am also paranoid a bit, this being my first pull, so maybe an over reaction and I need to just work it a bit.....
Old Jul 23, 2016 | 12:06 AM
Jaydoubleyou's Avatar
Jaydoubleyou
Yea I think you're over thinking it a bit, personally I would put some tension on it with the engine hoist. And then use a pry bar to try to get the motor to move a little. Once you have some movement I'd apply more pressure and repeat until you're clear of the mount.
|WYG|SS
Mar 14, 2026 07:38 PM
Rick Wallace
13
Jul 25, 2010 09:11 AM
trailpass
Mar 8, 2005 01:39 AM
house
1978 - 1996 Big Bronco
Apr 27, 2003 02:23 AM
