Patch or Replace; rust in the box
Old Jul 22, 2016 | 07:53 PM
chukar's Avatar
chukar
This is to be a replacement box for my '74 4x4. Mine is worse. Guy I got it from cut out this section of the front bed runner because it was toast just there. You can also see a few rust holes at the front of the bed just above the floor. The inside of the runner is pretty well rusted as well but nothing has gone through the floor yet, but it's only a matter of time. Living in SoCal, or what's left of it, the process may slow down but that's all.
So, should I just weld in something to get the runner as close to what it should be and perhaps do the same with that front of the bed, or replace the whole runner? As for option no. 2, I've done a lot of looking but not found that front runner for my year, or '73-79' trucks, anywhere. Depending on what you think about the replacement route, I'd really appreciate knowing if those front runners can be had anywhere, including wrecking yards.
Oh, knowing how I am with trucks I probably won't keep this more that 7-10 years if that influences your advice.
Thanks again, Vic
Old Jul 22, 2016 | 08:21 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No pictures.
Old Jul 22, 2016 | 09:14 PM
chukar's Avatar
chukar
Originally Posted by mikeo0o0o0
No pictures.
Picky, picky, picky!
On the other hand, this may help my cause.
Old Jul 22, 2016 | 09:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You're correct, there are no Ford dealers or obsolete suppliers that have that part (Front sill D3TZ-9910610-C) and no one reproduces it.
That is a fairly simple piece to repair though. I would cut it back far enough to get into good metal. Get a piece of sheet steel and cut it to size, bend to fit and butt weld in place.
One thing I would do. Before welding the piece in, Eastwood makes a rust encapsulator (Frame Saver) that is aerosol and has a 24" flexible tube, I would get a couple of cans and spray the inside of the crossmember to neutralize the remaining rust.
Old Jul 23, 2016 | 12:33 AM
chukar's Avatar
chukar
You're correct, . . . I would cut it back far enough to get into good metal. Get a piece of sheet steel and cut it to size, bend to fit and butt weld in place.
. . . I would get a couple of cans [of the Eastwood] and spray the inside of the crossmember to neutralize the remaining rust.
Thanks a lot. Just what I needed to hear: Simple, quick.
Gearstix
Paint & Bodywork
25
Jan 23, 2009 08:54 AM
RADUD
Oct 29, 2008 07:35 PM
custom cabby
Nov 24, 2007 11:20 AM
jeff303
Paint & Bodywork
May 15, 2004 08:54 AM
zukezake
Paint & Bodywork
May 9, 2002 08:42 AM
