6.0 electrical issues
Old Jul 22, 2016 | 08:19 AM
Big Red trucker's Avatar
Big Red trucker
03 f250 6.0.... replaced both batterys and volts have been around 11.9 to 12.9.. fluctuates alot. Checked alternator and passed. Noticed previous owner had supee glued pigtail on alternator due to locking pin breaking. Its on pretty tight but could this be my issue? If so ive heard about some being available for $5. Thanks in advance
Old Jul 22, 2016 | 11:31 AM
speedyford's Avatar
speedyford
Where are you reading the voltage from? Scan Gauges are usually .5 volts off actual. Voltmeter is the best and most accurate.
Old Jul 22, 2016 | 04:44 PM
Yahiko's Avatar
Yahiko
Also are the cable ends clean. Both the ground and power sides on both ends.
That means you may have to trace the ground cables to the frame and block.
The one on the passenger side is near the A/C compressor and frame and the driver
isde is under the air-filter near the frame head.
You test you can do with ha DMM (Digital Multi Meter) is a Voltage Drop Test.
Here is a example on Youtube.
The key thing being at high currents even a little increased resistance in a cable
can cost you a lot of power.
One place a problem can hide in under cable insulation. It may "look" good but
it can hide all sorts of corrosion and rob power. Never assume a cable is good
by looks. The Voltage Drop Test is free just you time.
Sean <BR>
6.0L Tech Folder
Old Jul 23, 2016 | 02:52 AM
Big Red trucker
I monitor volts from a autometer guage, a edge cs and torque pro. They all are pretty even. I also have disconnected both batterys and checked volts with fluke meter. In addition, my alternator wire is 0guage and a 200a fuse. All battery terminals are fairly new. No corrosion what so ever.. positive/negative wire are 0ga aswell. :/
Old Jul 23, 2016 | 03:16 AM
Yahiko's Avatar
Yahiko
Any of the digital gauges plugged into the OBD2 port are
subject to the wires of the trucks systems.
Even though the cables are new it free to do the test.
How did you have the alternator tested?
Sean <BR>
6.0L Tech Folder
Old Jul 23, 2016 | 03:43 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I didn't understand exactly where they used it, but dried super glue would be an insulator.
Old Jul 23, 2016 | 08:12 PM
Big Red trucker
I have a bluetooth adapter for torque pro, then guages hooked up through fuse panel
Old Jul 23, 2016 | 08:14 PM
Big Red trucker
The glue is on the end of the outside connector so is plasic on plastic
Old Jul 23, 2016 | 08:29 PM
Yahiko's Avatar
Yahiko
Use the steps from the voltage drop test and put one probe on the battery +
term and the other one on the stud from the alternator stud. Do this so that
that adaptor is part of the section your testing to see if that adaptor is adding
resistance to that circuit.
Sean <BR>
6.0L Tech Folder
Donzi Dude
Dec 3, 2016 11:08 PM
fearfactory
Sep 1, 2016 09:38 PM
KDAVID1
Jun 9, 2015 09:56 AM
texastech_diesel
Mar 20, 2015 01:51 AM
JackandEmma
Electrical Systems/Wiring
May 10, 2013 08:07 AM
