Electrical issue
Old May 9, 2013 | 03:54 PM
JackandEmma's Avatar
JackandEmma
Electrical issue
Ii have a question. I have a 1994 Ford Explorer XLT. It just died the other night. I have dim dome light, nothing else. I had the battery and alternator tested, both are ok. I get an occasional click when trying to start it. I also get an occasional beeping, the key in the ignition sound. Any I dieas? I`ve checked the fuses, and can`t find a broken one.
Old May 9, 2013 | 06:54 PM
projectSHO89's Avatar
projectSHO89
Check for a battery cable the has corroded inside the insulation near the battery, a very common failure for 1st Gen Exploders.
My old 93 Exploder (yikes, it's been gone for 12 years!) got left in a theater parking parking overnight back in the late 90s for this problem.
A voltage drop test across the suspect cables and connections will tell you where the voltage is getting lost.
Old May 9, 2013 | 07:34 PM
JackandEmma
I had found this issue just about two hours ago. There wasn`t any visible signs of corrosion, but inside the positive side clamp was where the problem was, both the main cable and the one that ran to the solenoid. I cut them back about an inch, washed the ends with coca-cola and baking soda. Fired right up as soon as got it back together. Thanks for your help. I`m Jack, and I`m new, but I`ll be around. Thanks again!
Old May 10, 2013 | 08:07 AM
JWA's Avatar
JWA
Glad to have ya here Jack, Emma too if she's listening in!
tbax46
May 26, 2015 09:56 PM
luv2offroad2
May 3, 2015 09:07 PM
texastech_diesel
Mar 20, 2015 01:51 AM
frdlvr35
Jul 13, 2011 07:10 AM
tmrenner
May 23, 2010 12:26 PM
