Urgent: Stranded: Please Help
Old Jul 23, 2016 | 12:32 PM
ShortBed'86's Avatar
ShortBed'86
Well guess its good you found out why it no run. Just bad you had to find out that way.
So you doing the fix in the stations lot or had it towed?
Dave ----
Free tow from my insurance company. Unfortunately, since I'm 600 miles from my tools I'm forced to have it fixed at a local shop. Two thumbs down.
Old Jul 23, 2016 | 04:36 PM
maytag906's Avatar
maytag906
I HATE when that happens.....
Old Jul 24, 2016 | 01:27 AM
kr98664's Avatar
kr98664
Originally Posted by ShortBed'86
Timing sprocket was completely worn smooth and timing was off.
Wow, that's not something you'd expect to have fail so suddenly.
Are you talking about the camshaft sprocket for the timing chain? Just curious, how did the shop find that? Did they find the ignition timing way off and go from there?
Old Jul 24, 2016 | 05:04 PM
FuzzFace2's Avatar
FuzzFace2
Most of the time that is when they let go, start & stop of the motor.
I did have a bow tie chuck a chain as I was making a slow 90* turn. Let off the gas before turn and was just giving it more as I was coming out and the motor just stop running. On the side of the road it cranked over real fast, no compression, and I knew what it was.
Hope it all works out good for you.
Dave ----
Old Jul 25, 2016 | 01:45 AM
ShortBed'86
Yup. They actually diagnosed it almost immediately and they were right on the money.
Old Jul 25, 2016 | 02:13 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
That's a good sign ... Although an unfortunate circumstance!
-Enjoy
fh : )_~
Old Jul 25, 2016 | 05:56 AM
Franklin2's Avatar
Franklin2
An immediate sign is when you crank it over. It's not a constant rpm when it cranks, it wavers in a pattern going up and down in rpm as the starter turns it over.
nighthawk285
Aug 3, 2019 08:08 PM
92F150XLT
General Automotive Discussion
Jun 8, 2005 02:05 AM
drtshtr301
Bronco II
Mar 23, 2003 11:58 AM
oregonlady
Jul 12, 2002 08:08 PM
